Format enum with custom values
Forum Home › Forums › Understanding the Software › Format enum with custom values
  • #17998
    oley
    I have a command to enable/disable switch.
    The values are 0 and 0xFF00.
    Format enums start with a value of 0.
    Is it possible to define an enum with different values, like in C#?
    public enum SwitchState
    Off = 0,
    On = 0xFF00
    #17999
    public double exsamp()
    if (Cmd==0) return 0;
    elseif (Cmd==1) return 65 280;
    else return double.NaN;
    there is no On or OFF in Cmd, numeric values are there, even if you use enumerations.
    #18000
    oley
    Thanks, I thought about some script but want to ask if there is another option.
    #18001
    when you use the Off-On enumeration and the command window has two corresponding buttons, a 0 or 1 is sent to your command as a double. Based on this, it is required to build a formula.
    #18002
    Cmd==0? 0 : Bitconverter.Double({ 00, FF, 00, 00, 00, 00, 00, 00})
    this option is also possible. just check the syntax.
