Localhost:10008 Not Working
Forum Home Forums Understanding the Software Localhost:10008 Not Working
  • #16930
    yotool
    On the very computer running Rapid SCADA I can successfully get to http://localhost/Scada.
    However, if I try to browse to http://localhost:10008, I get nothing.
    Netstat shows nothing listening on TCP/IP port 10008 on this machine.
    I never changed any IIS server ports for Rapid SCADA.
    Other installations of Rapid SCADA have no issues connecting via TCP/IP port 10008.
    What am I missing?
    • This topic was modified 7 months, 2 weeks ago by yotool.
    #16932
    WayneS
    The installer should have changed the port to 10008
    See https://rapidscada.net/docs/en/latest/installation/install-windows
    Also see the manual installation process- you may need to adjust IIS
    HTTP port 80 is used by Default Web Site. Use another port, such as 10008, or stop Default Web Site.
    #16934
    yotool
    OK, I figured this out.
    For some reason within IIS Manager, the “Scada” website was “underneath” the “default” website.
    I “created” a new “Scada” website pointing to the local ScadaWeb directory and edited this new website’s “bindings” to TCP/IP port 10008.
    …not sure how that got all jammed up like that.
    I never changed anything on purpose anyway.
    #16936
    OK.
    The similar topic is here.
