Forum Home › Forums › Understanding the Software › Formulas › Execute weblink in channel table
- This topic has 11 replies, 3 voices, and was last updated 1 year, 1 month ago by
August 13, 2025 at 2:14 am #16830
CCKOH
ParticipantHi Mikhail,
Good day to you.
I’m wish to know is that possible to open weblink by using channel table like the link function on the scheme view? The purpose of I need to use on channel table is because I need to apply Object right to this particular channel only.
I’m trying to set a channel as calculated output, output format: execute, output formula: URL:”www.exampledomain.com”, but this setting is not working.August 13, 2025 at 6:08 am #16832
manjey73ParticipantProbably not, it’s a plug-in for tables as part of PlgMain. Most likely, it needs to be improved
August 13, 2025 at 6:09 am #16833
manjey73ParticipantFor example, in addition to the “Rocket” – execute the command, you need to add something else. Or to add to this the ability to work with links.
August 13, 2025 at 2:52 pm #16837
Scripts are executed on server side, so they have no connection with a web browser.
How is the information expected to be presented to the end user?August 14, 2025 at 12:43 am #16841CCKOH
My idea here is to create a web application link on the channel table. The function of the application link is to shut down the machine. This feature cannot be accessed by everyone, only by the supervisor level. I’m thinking of applying object rights and roles on this calculated output channel and using the button on a scheme to execute this web application link. If the user logs in without the user rights and clicks the button, ‘Access Denied’ will be prompted by Rapid SCADA. The scheme is displayed in kiosk mode and I am setting it in Webstation so that it will be the first screen to load after login.August 14, 2025 at 10:50 am #16848
You can create a channel with an output formula that executes an external script to shutdown the machine.
But it’s not a good practice.August 14, 2025 at 10:51 am #16849
MikhailModeratorTo shut down a Linux machine it’s better to connect by SSH and execute a shell command.
August 14, 2025 at 1:49 pm #16851CCKOH
“You can create a channel with an output formula that executes an external script to shut down the machine.”
Could you advise me on what formula can be applied to the output formula to execute the external script?
For your information, I’ve set up an Nginx web server to listen to http://localhost:8080, which is the web application using a shell command to shut down the Linux machine. Do you have any ideas on how to incorporate http://localhost:8080 into the output formula so that when the output format is set to execute, it will open the link?
Thank you.August 15, 2025 at 11:42 am #16856
MikhailModeratorIn the Scripts table add
public double StartProcess() { Process.Start(@"/opt/scada/myscript.ssh"); return 1.0; }and create myscript.ssh containing the necessary commands.
Then use that function in the output formula.August 16, 2025 at 6:29 am #16858CCKOH
I tried using the Process.Start function with my .sh script, but it seems that this function does not support the command{xdg-open "$URL" >/dev/null 2>&1 &}, which is intended to open a web link. However, that’s fine; I’m just using the URL-link function in the scheme view, which is more convenient and straightforward. The only drawback is that we cannot set object and role restrictions on the specific web link itself.Thank you very much!
August 18, 2025 at 4:26 am #16868CCKOH
Just for update, Process.Start function is able to run the shell script even with xdg-open command. The only thing is need to properly set the user access of the files.
Thank you.August 18, 2025 at 11:46 am #16876
That’s interesting! -
