Cannot Access http://RapidScadaIP:10008 from Other Computers in LAN
Forum Home › Forums › Installation Issues › Cannot Access http://RapidScadaIP:10008 from Other Computers in LAN
  • #13314
    yotool
    I have Rapid Scada v.6.1 installed and running.
    From the localhost I can successfully connect to http://localhost:10008/Login to get to the Login page.
    The PC running Rapid Scada (Windows 10 Pro) has its firewall turned OFF for All modes Public, Domain, and Private.
    However I cannot get to http://rapid-scada-ip-address:10008/Login from another machine on the same local network.
    I CAN RDP the Rapid Scada host.
    I also can get to http://rapid-scada-ip-address:80 and see the default IIS web page.
    ** What am I missing?
    I’ve successfully done this on many previous versions of Rapid Scada (including configuring my local router’s port forwarding to get to Rapid Scada from anywhere in the world).
    • This topic was modified 3 years, 2 months ago by yotool.
    #13318
    yotool
    Sorry…
    I can be stupid at times.
    Although I had the “Windows Firewall” via “Firewall and Network Protection” DISABLED.
    The “Window Defender Firewall” was lacking/blocking incoming PERMIT rules for port 10008 (of course).
    …maybe others can learn from my mistake :>)
    • This reply was modified 3 years, 2 months ago by yotool.
    #13327
    Thank you for providing the cause of the issue.
    #16933
    yotool
    OK, I figured this out.
    For some reason within IIS Manager, the “Scada” website was “underneath” the “default” website.
    I “created” a new “Scada” website pointing to the local ScadaWeb directory and edited this new website’s “bindings” to TCP/IP port 10008.
    …not sure how that got all jammed up like that.
    I never changed anything on purpose anyway.
    #16935
    Thank you for the info.
