Forum Home › Forums › Communicating with Devices › Modbus › Logging fast I/O
- This topic has 30 replies, 3 voices, and was last updated 10 months ago by
August 12, 2025 at 10:03 am #16821
zarsss
ParticipantWhat would be a good approach to log fast inputs (0.1s.-0.2s.) and fast outputs (0.3s) to Rapid scada? Even with adjusting poll rate and data refresh rate, it is not too reliable. Any suggestions to improve this? Thank you.
August 12, 2025 at 10:24 am #16822
MikhailModeratorSeems, that a good approach would be to change a communication protocol. It would be more efficient to receive bunch of data that contains many data points.
August 13, 2025 at 11:33 am #16834zarsss
ParticipantThank you.
August 18, 2025 at 10:09 am #16871zarsss
ParticipantCurrently, while viewing data is one value per minute. Is it possible to make it to record more often? Just for a selected channel, not all of them.
August 18, 2025 at 10:47 am #16872
manjey73ParticipantIt can be adjusted from 1 second. To do this, create the appropriate archive and specify it in the channel mask. Make an additional table with the Archive code. If necessary, configure the profile of the Charts Pro for display.
August 18, 2025 at 11:43 am #16873
MikhailModeratorYou can write data on change. It is supported by PostgreSQL archives.
It’s needed to create a new archive in the configuration database and in the Server settings. The created archive should not be marked as default. Then you can set an archive mask of the channel to write that channel to the certain archive.
Ask for the details if needed.August 19, 2025 at 8:45 am #16878zarsss
ParticipantI have to ask for the details. I created an archive in Server tab, but cannot see it in the configuration database tab. So I assume, I have done something wrong. Or, I just don’t what I am doing.
August 19, 2025 at 9:00 am #16879
manjey73ParticipantAfter creating the archive, it must be assigned in additional project tables by analogy with the existing ones.
August 19, 2025 at 9:59 am #16880
MikhailModeratorManually add a row in the Archives table.
If you provide screenshots, I can check.August 19, 2025 at 2:27 pm #16882zarsss
Participanthttps://ibb.co/RTsP3js7
https://ibb.co/fV8FHcmC
https://ibb.co/MxZ6kGVQ
https://ibb.co/TqgWyksgThis is what I have done so far.
August 19, 2025 at 2:33 pm #16883
manjey73ParticipantYour archive is listed as the Current one, which is probably incorrect. It must be Historical beforehand
August 20, 2025 at 7:43 am #16885zarsss
ParticipantIs there a way to check if there is actually anything written in that archive I created?
August 20, 2025 at 7:55 am #16886
manjey73Participant1 Download additional utilities and replace them with new libraries from the Scada package.
2 Configure the Presentation Table and Chart Pro to display this particular archive
August 20, 2025 at 7:59 am #16887
manjey73ParticipantAugust 20, 2025 at 8:04 am #16888 -
