Format – greater than 1000 characters
Forum Home › Forums › Understanding the Software › Format – greater than 1000 characters
  • #16938
    WayneS
    Greetings
    Is it possible to have a format with more than 1000 characters? I have some registers whose values can be 0-600 and each value represents a different status – e.g.
    RFI Overcurrent Persistent = 252
    Voltage difference exceeded = 253
    VDC not reached = 254
    Battery open detection = 255
    Using enum format I quickly hit the 1000 character limit
    thanks
    #16939
    Wow. I didn’t expect that there could be so many enumerations. I used Text in SVG when I had an enumeration with omissions in the values. And I used dynamic drawings and a collection to control the output, respectively.
    The situation is a little different, but this is how you can work around this problem.
    #16941
    You could manually edit Format.xml in a text editor, e.g. Notepad++.
    Then reload the project or configuration database.
    #16942
    The string length is limited by the Administrator application. Actual length can be bigger.
    #16944
    WayneS
    Thank you for the replies. The dynamic drawings/collection is a good option, albeit alot of work. I will try editing the format.xml and see how it goes. This should be relatively easy as I have the values in a spreadsheet. Incidentally I have mutiple registers with different meanings/text.
    regards Wayne
    #16945
    WayneS
    Thanks all, Editing the format.xml in notepad++ worked 100%. I have now have some formats of 5000 characters long. I used excel and notepad to create the format and place in format.xml, then reloaded the application and downloaded it to test.
    regards
    Wayne
    #16948
    Thank you for the update.
    Note that in the Format column, it’s possible to write one value per line without semicolons. It may be more comfortable to edit.
