Viewing 15 posts - 3,766 through 3,780 (of 6,302 total)
  • in reply to: Problem with remote server #6818
    Web application uses port 80. You should find and enable the existing rule in Windows firewall settings.
    First of all, I must thank you for the wonderful job you’ve made (and keep making) with Rapid Scada. I learned a lot using it, aswell reading the forums.
    in reply to: Problem opening rapidscada in browser #6817
    I think, you should continue the other steps of the installation sequence.
    in reply to: Using Custom Webpage in Scada Webbeta 5.0 #6809
    Probably, namespace was renamed. Try deleting using and use the VS suggestions.
    Or post the error here.
    in reply to: UI for Linux #6808
    The Administrator app can run on Linux. But has some restrictions in editing table data.
    To run the app, type
    mono ScadaAdmin.exe in the proper directory
    in reply to: Problem opening rapidscada in browser #6804
    This problem is related with the modules libapache2-mod-mono and mono-apache-server4
    Try to repeat the step
    sudo apt-get install libapache2-mod-mono mono-apache-server4
    and check if there are some errors during installation.
    in reply to: fit to screen/width by default #6803
    Scale of a scheme is stored in browser cookies.
    To check this:
    1. Change the scheme scale.
    2. Logout and login again.
    3. Open the scheme.
    You should see the scale that was previously set.
    If it doesn’t work, please write here.
    in reply to: Using Custom Webpage in Scada Webbeta 5.0 #6798
    Hi Matt,
    CustomPageExample
    In case you need to develop a web page, I suggest to use the above example. The 1st and the 2nd ways are preferable if you develop a separate application.
    If the above pages can be part of the existing Rapid SCADA framework, that would be great.
    It can be a part of Rapid SCADA web app if the backend is written using .NET Framework. However, the mentioned example written on clear HTML and JS.
    • This reply was modified 6 years, 1 month ago by Mikhail.
    in reply to: Administrator Upload Error #6797
    In Task Manager / Services, the SCADA programs were not running
    They run as the system user. You should check the full task list.
    in reply to: Administrator Upload Error #6793
    This error means that the Agent service is not started or started with a error.
    Check C:\SCADA\ScadaAgent\Log\ScadaAgent.log for the details.
    May be it’s enough to restart a computer to start the service.
    in reply to: can not uploading in raspberry Pi4 #6791
    You should grant the writing writes to the Projects directory for your user. For example, you can set the owner of the directory.
    The Administrator application has some restrictions on Linux. I suggest creating projects on Windows and then upload them to a Linux machine.
    in reply to: Send command button – change register bit #6787
    Set a formula for the output channel.
    Something like this (not tested):
    (ushort)Val(101) | ((Cmd > 0 ? 1 : 0) << 2)
    There the input channel #101 stores the current value of the register.
    in reply to: Conecting to Beckhoff BC9100 PLC’s #6783
    1. I suppose, encode time to Unix time. This is a 32 bit integer.
    2. Yes. Create new calculated channels and use GetBit function
    3. The web manual and this forum.
    The above are the general ideas. We can discuss them in details.
    in reply to: Command is canceled #6782
    Definitely. That’s what I mean asking about used modules.
    in reply to: Command is canceled #6779
    Thank you for the screenshots.
    Do you use any modules with SCADA-Server?
    This issue may be caused by DB Export module.
    in reply to: Command is canceled #6777
    Please create the screenshots of the settings and provide logs.
