Problem with remote server
Forum Home › Forums › Communicating with Devices › Problem with remote server
  • #6816
    OtavioF
    Good day, Mikhail.
    First of all, I must thank you for the wonderful job you’ve made (and keep making) with Rapid Scada. I learned a lot using it, aswell reading the forums.
    Now for the trouble I’m facing, I’m not able to access the web application of a remote server. I’m able to connect, download and upload through the Administrator, however, when I try to access the link http://*remoteIP*/Scada, I get:
    (61) Connection refused
    I’ve port forwarded both 10000 and 10002 ports on Windows Firewall, router and modem on the remote server.
    What am I missing?
    Thank you in advance
    #6818
    Web application uses port 80. You should find and enable the existing rule in Windows firewall settings.
    #6865
    OtavioF
    Good day, Mikhail.
    Thank you for your reply. That’s exactly what was missing. I had to portforward the 80 port on my radio internet receiver and on my router. Now my system is fully working.
    Thanks again.
