Administrator Upload Error
Forum Home › Forums › Installation Issues › Administrator Upload Error
  • #6790
    Matt3
    Hi
    I’ve just installed Rapid SCADA 5.8 on a Windows 10 pro pc.
    Installation went ok.
    I then run the Administrator program and loaded the DemoProject-en-GB.
    I did not change any settings but just clicked the upload button.
    I get the error message “Error Uploading configuration. There was no endpoint listening at http://localhost:10002/ScadaAgentSvc/ that could accept the message……”
    localhost/ returns the default iis page
    localhost/scada, when I try to login with admin and 12345, after I click the login button, it returns with “Server is unavailable”
    Matt
    #6793
    This error means that the Agent service is not started or started with a error.
    Check C:\SCADA\ScadaAgent\Log\ScadaAgent.log for the details.
    May be it’s enough to restart a computer to start the service.
    #6794
    Matt3
    Thank you. It’s working now.
    In Task Manager / Services, the SCADA programs were not running.
    Matt
    #6797
    They run as the system user. You should check the full task list.
