Conecting to Beckhoff BC9100 PLC’s
Forum Home › Forums › Understanding the Software › Conecting to Beckhoff BC9100 PLC’s
  • #6781
    Celestino
    HI,
    I installed your Rapid Scada software for a proof of concept, more precisely to test the control of some BC9100 PLC’s from Beckhoff, using Modbus.
    I read your documentation and in order not to reinvent the wheel, I asked for your help with the questions below:
    1 – What is the best way to send the Date and Time to the PLC?
    2 – Is there a standard way to extract a “Bit”, from a Holding Register?
    3 – Is there a more detailed technical manual for your software?
    Thank you in advance for your help.
    Celestino Camacho
    • This topic was modified 6 years, 5 months ago by Mikhail.
    #6783
    1. I suppose, encode time to Unix time. This is a 32 bit integer.
    2. Yes. Create new calculated channels and use GetBit function
    3. The web manual and this forum.
    The above are the general ideas. We can discuss them in details.
    #6785
    Celestino
    Hi Mikhail,
    I will try, if necessary I will contact again.
    Thank you
