Viewing 15 posts - 2,161 through 2,175 (of 6,296 total)
  • in reply to: Map code #11691
    How to turn the map pin to green if >0 and turns red if 0”
    Use a channel formula mentioned above or similar.
    in reply to: Map code #11687
    Unfortunately, wetransfer.com does not work in Russia, so I can’t check the file.
    Please upload the file to another file hosting.
    in reply to: Ошибка ASP.login_aspx #11684
    The above error means that ASP.NET has not been properly installed.
    If you are starting from scratch, I suggest to try Rapid SCADA 6.
    This forum is in English. If you prefer Russian, use https://forum.rapidscada.ru/
    in reply to: Map code #11683
    Probably, you should create a new channel of the calculated type with the formula
    Val(101) <= 1 ? 1 : -1; Stat(101)
    where 101 is the source channel number
    in reply to: Map code #11682
    According to the manual: “0 – channel not specified; positive channel value means the location is normal, otherwise the location needs attention”.
    So channel formula might be: Cnl <= 1 ? 1 : -1
    in reply to: Channels Communication and Reset #11681
    The the module is required to send commands automatically according to the specified conditions.
    I recommend to get the current time once:
    DateTime curTime = DateTime.UtcNow;
    in reply to: Export channel data to excel for longer periode of time #11674
    May I know what is the proper procedures to install V6?
    Instructions will be created soon.
    How about the existing V5 projects?
    There will be a converter utility.
    Do I need to uninstall V5 first?
    It’s possible to use both on the same machine. But it is easier to deploy a new virtual machine for v6.
    in reply to: Channel Status and Channel Value #11673
    I mean that channel status can be written as value of another channel.
    in reply to: Number to be displayed at WebStation #11672
    Please read this. Item 7
    in reply to: Cnl vs Val #11671
    Cnl and CnlVal are variables.
    Val() and Stat() are functions.
    in reply to: Real vs Calculated Real #11670
    All channels may use formulas, but formulas are calculated in different moments.
    You can find more details here.
    in reply to: Table Summary (More document support needed) #11669
    Project can contains many channels. But a table view should not contain all of them. Make several table views instead.
    in reply to: Table #11668
    Probably no. I even can’t imagine it.
    in reply to: Notification plug in (trial key vs paid registration key) #11667
    OK
    in reply to: Input channels and Output channels #11666
    Can the number of input channels need to equal to the number of output channels?
    Amount of input and output channels may be equal or not equal, depending on the needs.
    If an output channel is used for changing the input channel, I recommend to use the same IDs for them. It is important to transfer project to v6 later.
