Channel Status and Channel Value
Forum Home › Forums › Understanding the Software › Channel Status and Channel Value
  • #11588
    victorlam
    Under Webstation, there is a table in which this is a summary table.
    May I know if I can show both channel status and channel value for the input channel eg 101. or let’s say, I must need to use two separate rows to display the channel status and channel number values?
    It seemed that this is a bit difficult task.
    #11629
    To display channels statuses as numbers, create extra channels of the calculated type that contain statues.
    #11648
    victorlam
    In that case, you mean one row is channel value.
    one row is the channel status.
    One data box cannot show both values at the same time.
    #11673
    I mean that channel status can be written as value of another channel.
    #12524
    emhatek
    Hi Mikhail,
    I found channel statuse table. I’m success to put “statuses” phrase inside the property table fot dynamic text foreground color. However, how to select the statuses color to second, third excep main.
    Please your advice.
    Regards
    Emhatek
    #12528
    The Second Color and Back Color columns were made for future use. Currently, only Main Color is available.
