Forum Home › Forums › Understanding the Software › Number to be displayed at WebStation
- This topic has 10 replies, 2 voices, and was last updated 4 years ago by
November 14, 2022 at 1:50 pm #11520
victorlamParticipantHello,
I have a value read from register 30002. The initial value is 65535 in which this is an insignificant value. Due to the alarm trigger, it will be changed to a significant value eg 100 or 500 or others, not 65535.
At WebStation, how can I make the value of 65535 not shown (or disappeared) unless the value has been changed to other values, then this value will be displayed?
Please advise if this can be implemented.
November 15, 2022 at 2:03 pm #11544
Set the undefined channel status if value is 65535 with a formula.November 17, 2022 at 3:33 pm #11573
Thanks for your guidance support.
I try to set the undefined status with color as white as the table summary background is white.Then the formula is
public int Checkstatus()
if (Cnl=65535) return 0;
else return 1;
}Under input channel 1, then the syntax is Cnl;checkStatus()
However, there is no change or there is error after upload the project file.
Please help to advise the solution on this.
November 18, 2022 at 11:38 am #11576
In case of an error, please provide the error message.November 18, 2022 at 3:04 pm #11584
victorlamParticipantHere you are:-
2022-11-18 22:56:46 <LAPTOP-JH81V3B5><SYSTEM><ERR> Error compiling the source code of the formulas:
Line 516, column 5: error CS0200: Property or indexer ‘Scada.Server.Engine.CalcEngine.Cnl’ cannot be assigned to — it is read only
Line 516, column 5: error CS0029: Cannot implicitly convert type ‘double’ to ‘bool’
2022-11-18 22:56:46 <LAPTOP-JH81V3B5><SYSTEM><ERR> Normal program execution is impossibleNovember 19, 2022 at 3:47 am #11585
Let me explain my situation here.
Value of a register eg 30001, the value at initial state is 65535 (FFFF in heximal value). This is an unrelevant value or non-meaning value. So I do not want to display this FFFF or 65535 value. When there is a trigger from the sensor, it will be changed as eg 10 or 200 355 or 311 or any value not 65535.
How can this be done? I have already used the formula but not successful. May be my formula is not correct.
November 19, 2022 at 3:48 am #11586
victorlamParticipantAnd this value (not 65535) needs to be displayed or shown.
November 19, 2022 at 7:28 am #11590
victorlamParticipantOr my situation was not clear. And let me brief the status as follows:-
30001 = 0/1/2/3
0=NORMAL, 1=LEAK, 2=BREAK, 3=LEAK&BREAK
This register value can be used at the unit function and represented with different status of the register 30001.30002
default value = FFFF (65535). This value is not significant and should not be displayed and need to display any number other than 65535.
Suggest to use the formula. Then the formula is as follows:-
public int Leak() { if (Cnl>=65535) return 0;
else return 1}After the apply of the formula function, I cannot implement with the requested effect. Please help to advise if anything is missing here. Or I have the wrong interpretation.
November 21, 2022 at 9:58 am #11628
MikhailModeratorif (Cnl=65535) return 0;has wrong syntax. C# uses == as equality operator.November 22, 2022 at 2:28 pm #11649
Thanks for your support so far. Eventually I have successfully executed my request as follows:-
Formula is below:-
public int LeakLocation()
else return 1; }Under Input channel number 102 box; I use “Cnl/10;LeakLocation()” for the formula.
But my concept is still not clear and would like to get your explanation on this.
If the value is 65535, then it will be —. If the value is not 65535 eg 47 or 35, then it will display eg 4.7 or 3.5 etc.
My question is how did Rapid SCADA handle the formula box with both channel value and channel status at the same time. This is a bit confusing.November 23, 2022 at 11:52 am #11672 -
