Real vs Calculated Real
Forum Home › Forums › Understanding the Software › Real vs Calculated Real
  • #11601
    victorlam
    May I know when I should use Real and Calculated Real for channel type? I have encountered with server error due to this application error.
    I try to modify as Real and works again.
    Please kindly advise if I should use Calculated Real all the time for the simplity purpose.
    #11626
    “Real” channels are measured by devices.
    “Calculated” channels are calculated based on real channels.
    #11651
    victorlam
    Just to clarify, do you mean “Real” that there is no manipulation or direct value from the channel. Then calculated means that there is formula or calculation behind.
    If there is no manipulation, can I still use Calculated and pay safe without any error?
    #11670
    All channels may use formulas, but formulas are calculated in different moments.
    You can find more details here.
