Forum Home › Forums › Understanding the Software › Export channel data to excel for longer periode of time
- This topic has 11 replies, 3 voices, and was last updated 3 years, 7 months ago by
November 18, 2022 at 9:57 am #11575
Jure
how can we export data from some channel to excel? I know that you can do this inside graph view and from reports but time period is limited to 32 days.November 18, 2022 at 11:40 am #11578
A period limit can be configured in Rapid SCADA 6.November 18, 2022 at 11:48 am #11580Jure
ParticipantHi, we don’t want to limit it but lets say export data for one or multiple channels to excel for whole year.
November 21, 2022 at 10:00 am #11630
In Rapid SCADA 6 you can set as big limit as you need. For example, 365 days.November 21, 2022 at 1:04 pm #11633Jure
ParticipantI am asking about Rapid SCADA 5, if there is any solution to export data.
November 22, 2022 at 1:47 pm #11642
MikhailModeratorIn Rapid SCADA 5 you can get reports one by one and join them manually.
We add new features in Rapid SCADA 6.November 22, 2022 at 2:20 pm #11647
victorlamParticipantHello,
It seemed that it would like to persuade to use Rapid SCADA V6 as soon as we can.
May I know what is the proper procedures to install V6?
How about the existing V5 projects? Can we use or we need to rebuild the project file again?
Please help to advise all the details about V6 installation and changer over.
Do I need to uninstall V5 first? Sorry for many questions to ask.November 23, 2022 at 11:56 am #11674
Instructions will be created soon.
There will be a converter utility.
It’s possible to use both on the same machine. But it is easier to deploy a new virtual machine for v6.
March 7, 2023 at 9:30 am #12186Jure
ParticipantI have installed V6, where can I configure that I CharPro will draw graphs for more then 31 days or to export data for more then 31 days?
March 7, 2023 at 1:17 pm #12188
MikhailModeratorPlgChartPro.xml, parameter MaxFixedPeriod
ScadaWebConfig.xml, parameter MaxReportPeriodMarch 7, 2023 at 1:30 pm #12190Jure
ParticipantIn PlgChartPro_Reg.xml is only RegKey and in ScadaWebConfig.xml I used search and there is no paramter that Would start with Max.
I have verison of scada 6.0.0.1 and PlgChartPro is 6.0.0.1.-
This reply was modified 3 years, 7 months ago by
Jure.
March 8, 2023 at 9:37 am #12192
MikhailModeratorThe parameter is in PlgChartPro.xml, not PlgChartPro_Reg.xml. Look for PlgChartPro.xml in the distributive.
