Viewing 15 posts - 2,116 through 2,130 (of 6,296 total)
  • in reply to: Version 6 issues #11822
    Make sure that the Agent service is running without errors by checking its logs.
    in reply to: OPC UA data limit #11821
    If you need some help with that, provide screenshots and logs.
    in reply to: Internal server error (500) #11820
    Make sure that AspNetCoreModuleV2 is installed like described here.
    in reply to: Chart Pro Trend Colors #11810
    Could you provide a link to a screenshot of your existing dashboard? It would help to understand the issue.
    in reply to: Version 6 issues #11808
    That’s true, Rapid SCADA 6 is significantly different than version 5. It’s more simple and handy. Documentation will be added on https://rapidscada.net/docs/
    Currently, there are instructions how to install the new version. Configuration manuals will be created after porting the existing modules, drivers and plugins.
    in reply to: What is the default Password in version 6 #11802
    Use EncryptPassword from this folder.
    In the next version of the Administrator app, there will be a UI feature for encrypting passwords.
    in reply to: V6 plug in #11801
    The keys can be updated for free for the same computer.
    in reply to: Bulk Creation of Devices and Communication Lines #11795
    You should reopen the project to read the changes in the tables.
    in reply to: OPC UA data limit #11794
    Thank you for the update.
    May be it would be more comfortable if you create separate devices (like CONTROL_2 etc.) on the same communication line. I mean if they related to different physical devices.
    in reply to: RAPID SCADA WINDOWS FEATURES REQUIERED #11793
    Hello Tony,
    There are no special recommendations.
    Please use Microsoft docs for installing IIS on Windows server.
    in reply to: ScadaClient.GetSlice #11787
    Every execution of the above code a client requests different data points. Probably, they don’t exists. Try specifying particular timestamp.
    in reply to: hiding a channel in chartPro #11785
    Also needed screenshots of the Objects and Views tables, and operator’s interface.
    in reply to: Bulk Creation of Devices and Communication Lines #11784
    When I try to edit .xml file like you said above, the new config is not added in the Administrator’s channel table after “upload configuration”.
    Please provide more info what file do you edit and how.
    in reply to: hiding a channel in chartPro #11774
    Could you provide screenshots of the existing configuration?
    in reply to: Rapidscada.net/stats #11773
    Don’t forget to download the changed configuration into the project.
