ScadaClient.GetSlice
Forum Home › Forums › Development and Integration › ScadaClient.GetSlice
  • #11779
    Zeus
    I use ScadaClient to get slice data from influxdb
    ScadaClient.GetSlice(ArchiveBit.Minute, DateTime.UtcNow.AddMinute(-1), new int[] { 101 })
    and it returns scadadata undefined stat 0 val 0
    #11787
    Every execution of the above code a client requests different data points. Probably, they don’t exists. Try specifying particular timestamp.
    #12013
    Zeus
    I save data into influxdb per secend.
    How can i get cnl data an hour ago.
    #12020
    Could you clarify the question?
    #12021
    Zeus
    I use influxdb storage history data.
    I can use api GetTrend and GetCurrentData get data from influx.
    When i use getslice
    the influxdb has cnl 101’s data every secend.
    If i want to get cnl 101’s data at “DateTime.UtcNow.AddMinute(-1)”. how can i make it?
    #12033
    To get a slice, you need to specify the exact timestamp. There is a very low chance that data exists exactly at DateTime.UtcNow.AddMinute(-1).
    To be able to get slices, you should write data with a period. And specify the exact timestamps that fits the writing period.
    #12034
    May be we should add a method to get values closest to the specified timestamp.
    #12039
    Zeus
    OK I will try
