RAPID SCADA WINDOWS FEATURES REQUIERED
Forum Home › Forums › Installation Issues › RAPID SCADA WINDOWS FEATURES REQUIERED
  • #11728
    tonielhage1
    Hello every one.
    I can find the windows features .NET and IIS components required for installing and running rapid scada for windows 7 and 10. But I need these features for windows server 2008. Thanks in advance for your cooperation.
    tony
    #11729
    Windows Server 2008 is not recommended, because it’s too old. However, Rapid SCADA may work on it.
    You should add a web role to the server configuration, link.
    What version of Rapid SCADA do you install?
    #11731
    tonielhage1
    i will install Rapid SCADA 5.8.4 on win server 2008 can i?
    #11734
    System Requirements declares that you can install Rapid SCADA 5.8 on Windows Server 2008 R2 SP1 or later
    #11737
    tonielhage1
    Hello.
    Can we make Virtual Machine windows 10 on windows server 2008 and then put put the features .net and iss of the windows 10 or only we should add a web role to the server configuration.
    Tony
    #11741
    Yes, you can use the both approached.
    #11789
    tonielhage1
    Hello
    1-the server is “Windows Server 2012 R2 Standard” and not server 2008.
    so before installing rapid scada application on it, I should follow the instruction in the following link: https://learn.microsoft.com/en-us/iis/get-started/whats-new-in-iis-8/installing-iis-8-on-windows-server-2012?source=recommendations
    is it right?
    2- is there any other recommendations especially we need to access the rapid scada project from the peripheral computers connected to the server
    thanks in advance
    tony
    #11793
    Hello Tony,
    There are no special recommendations.
    Please use Microsoft docs for installing IIS on Windows server.
