hiding a channel in chartPro
Forum Home Forums Understanding the Software hiding a channel in chartPro
  • #11748
    AFP
    Is it possible to set a channel to be hided in chartPro ( or any other plugin ) ?
    Nb: I m using version 6
    • This topic was modified 3 years, 8 months ago by Mikhail.
    #11749
    AFP
    * to be hidden
    #11750
    Chart Pro displays trends of the selected channels.
    Do you mean to provide access rights?
    Could you explain the question?
    #11751
    AFP
    Yes, it is about acces right to select a channel for a particular user ( or even all user).
    The goal is that I don t want users to see some channel from ChartPro.
    #11760
    1. Create custom roles in the Roles table.
    2. Specify object rights.
    3. Assign object for views in the Views table.
    4. Set roles to users.
    #11762
    AFP
    Thank you for your reply.
    But with these steps I can only hide object in scheme but in my case I would like to hide a defined device’s channel so that it can’t be selected in chartpro.
    #11768
    Rights are assigned on objects. Objects can have parents and children.
    You could create a child object, set it to a channel, and assign necessary rights.
    #11771
    AFP
    I’m sorry but I really don’t see how to do that.
    Please, I need some steps.
    #11774
    Could you provide screenshots of the existing configuration?
    #11775
    AFP
    Also needed screenshots of the Objects and Views tables, and operator’s interface.
