Forum Home › Forums › Uncategorized Issues › Chart Pro Trend Colors
- This topic has 4 replies, 2 voices, and was last updated 3 years, 8 months ago by
December 27, 2022 at 1:41 pm #11809
DF
ParticipantHello,
Is it possible to change the trend colors in chart pro when there is multiple charts on a dashboard?
I have 6 charts on the dashboard and would like them to have individual colors if possible.
I can see the trend colors in PlgChartPro.xml. Is it possible to add a color for separate charts in DashboardExample1.xml? If so, could you provide an example of where in the widget type this may possibly go?
Many thanks
DF
December 27, 2022 at 2:10 pm #11810
Could you provide a link to a screenshot of your existing dashboard? It would help to understand the issue.
December 27, 2022 at 4:27 pm #11813DF
ParticipantHi Mikhail,
The link below should show you the dashboard with multiple charts. Apologies for it being a picture and not a screenshot. I’m away from the desktop.
https://drive.google.com/drive/folders/1mY7RD_aw9BON1AVVANsuPkLIn40wRO47?usp=sharing
I was wondering if there was a way to change the individual trendline color for each chart. For example, in the picture, the bottom three charts (apparent, active, reactive power) to have individual colors of red, blue and green respectively to match the trendlines from the top right chart called power levels.
This reply was modified 3 years, 8 months ago by
DF.
December 28, 2022 at 10:14 am #11826
Thank you for the photo.Chart Pro for version 5 has a single configuration file. To set different colors for different quantities, you can define new YAxis with the specified Quantity ID in PlgChartPro.xml.
Chart Pro for Rapid SCADA 6 may have multiple configuration files. You can use the above method, or create different configuration files and specify them for dashboard. But, for now Dashboard Plugin for version 6 does not exist. So I wrote the 2nd method for the future use.
December 28, 2022 at 10:17 am #11828
MikhailModeratorSorry, I checked the manual https://rapidscada.net/docs/en/5.8/modules/plg-dashboard and found that you can specify chart configuration file for v5 also. Please choose a method that is more comfortable for you: specify axes in the single file or create many files. Or combine the both methods.
