Forum Home › Forums › Understanding the Software › Version 6 issues
- This topic has 8 replies, 2 voices, and was last updated 3 years, 10 months ago by
victorlam.
December 27, 2022 at 9:21 am #11807
victorlamParticipantHello,
I tried to install the version 6. The installation is successful.
Then I tried to test a simple project and encountered the target machine not authorized.I found that version 6 is totatally different from V584 version. May I know if we have any documentation to support the version 6?
Any guidelines to be familiar with version 6? Or any video to support the success of using version 6? At the moment, I need to step back with version 5_8_4 first.December 27, 2022 at 12:07 pm #11808
That’s true, Rapid SCADA 6 is significantly different than version 5. It’s more simple and handy. Documentation will be added on https://rapidscada.net/docs/
Currently, there are instructions how to install the new version. Configuration manuals will be created after porting the existing modules, drivers and plugins.December 27, 2022 at 4:36 pm #11815
victorlamParticipanthello,
Thanks for the reply. Please help to advise how can I solve for this error message:
Upload configuration
Test Agent connection
Error uploading configuration
No connection could be made because the target machine actively refused it. [:ffff:127.0.0.1]:10002This is the first message that cannot handle without any guidance.
December 28, 2022 at 10:05 am #11822
Make sure that the Agent service is running without errors by checking its logs.January 2, 2023 at 6:51 am #11842
Now I can upload the configuration.
What I have to implement to fix the issues:-
1/Reinstall the V6 again
2/ Follow the instruction to set up IIS sectionHowever, the new Webstation for V6 is totally different.
May I know where is the configuration and plug in the Webstation now?
Can you help to support more documentation for V6?
I have checked the existing listed documentation for V6. It is not detailed enough as done in V584 before. We expect if the team can help for the more details in the documentation and can follow the step by step as an example.January 2, 2023 at 8:55 am #11846
Webstation is configured using the Administrator application.
Documentation will be added after porting the modules.
January 6, 2023 at 9:25 am #11906
Then at the Webstation, it will be for browsing only and all the configuration and set up must be done via Administrator including the previous plug in authorization.January 6, 2023 at 10:32 am #11912
Yes. This approach helps to avoid loosing the configuration changes.
Which plugin do you mean?
January 7, 2023 at 3:58 am #11915
I mean the Chartpro plug in and if possible notificaton also.
