Could you clarify the question?
MikhailModeratorIn what moment did you get that error?
You should install Agent on computer 2 to be able to upload configuration to it using the Administrator app.
To cancel a command, an output channel formula should return double.NaN or null, depending on the required conditions.Button component can be bound to an input channel that allows to hide or disable a button. But the same command can be sent from another table view, for example.
MikhailModerator
MikhailModerator🙂
MikhailModeratorMay be you need a kiosk mode of the browser.
Such behavior depends on a browser. In Chrome, if you start full screen mode by pressing F11, it does not exit on page navigation.
Open Config/ScadaInstanceConfig.xml for editing. Set ActiveStorage to PostgreSqlStorage, and restart Rapid SCADA services.
According to the log, the modem does not respond:Receive: no data
You could compare with the previous logs.
Check connection settings.-
This reply was modified 3 years, 5 months ago by
MikhailModerator🙂
Weird. What is written in Agent settings and log?
MikhailModeratorThank you for finding this bug.
Please download and update the plugin again. Now it should work in Scheme Editor also.
Note: plugin registration is not needed for editing schemes.
It’s possible. Click Main Menu – Reports -…
If you delete the existing configuration files, is possible to upload new configuration? -
