Disable Automatic Control Module v5
Forum Home Forums Understanding the Software Disable Automatic Control Module v5
  • #12014
    cooldjmc
    Hi, is it possible to deactivate Automatic Control Module or disable sending commands from a scheme view, like toogle component or button.
    Or there is a way to inhibit Rapid Scada to send commands from scheme view ( like enable/disable automatic mode)
    Thanks,
    • This topic was modified 3 years, 4 months ago by cooldjmc.
    #12018
    To cancel a command, an output channel formula should return double.NaN or null, depending on the required conditions.
    Button component can be bound to an input channel that allows to hide or disable a button. But the same command can be sent from another table view, for example.
