Remote Communicator Error
Forum Home Forums Runtime Bugs Communicator Bugs Remote Communicator Error
  • #12016
    TroyV23
    I setup a test RapidScada environment on one machine to make sure my modbus configuration was correct, and everything worked perfectly. Now I am trying to separate the Server from communicator, and run them on 2 different computers.
    Computer 1: RapidScada Server, Webstation,
    Computer 2: Communicator
    When I run communicator on Computer 2, I get an error: saying no endpoint listening at 192.XXX.XXX.XXX:100000/ScadaAgent/ScadaAgentSvc/
    There is a firewall between the machines, and have opened ports 10000 and 100002.
    I have confirmed Agent running on both machines.
    Does this arrangement require the RapidGate module? (I don’t have it installed)
    #12017
    Not required. You have a PC with a Communicator should be in a separate instance, in which the server address should be specified in the Communicator settings – the 1st PC
    #12019
    In what moment did you get that error?
    You should install Agent on computer 2 to be able to upload configuration to it using the Administrator app.
    #12023
    TroyV23
    I have Agent installed in both places and it is confirmed to be running in task manager. Is there any other configuration I may be missing? The error appears as soon as I try and upload configuration. It is never able to run communicator.
    I have defined the server address in Communicator, does the server need to know the address of the communicator as well?
    • This reply was modified 3 years, 5 months ago by TroyV23.
    #12032
    No.
    Make sure that you try to upload configuration to the proper instance.
    Also try to connect to the remote Agent by a utility, like telnet using IP and port 10002.
    Check the Agent connection in the instance profile. Port should be 10002.
    #12299
    TroyV23
    Thank you, it turned out to be a firewall issue between 2 networks.
