V6 – Extra Scheme Components
Forum Home › Forums › Understanding the Software › V6 – Extra Scheme Components
Viewing 15 posts - 1 through 15 (of 15 total)
  • #11953
    grhsc
    Does Extra Scheme Components have a version that supports V6? Or is the current version compatible with V6?
    thank you
    #11956
    For version 6 you need the appropriate version of components.
    Extra Scheme Components 6 will be published with the next Rapid SCADA release.
    #11963
    grhsc
    Can you estimate the release date of the Extra Scheme Components 6 version, it is really useful
    #11970
    Approximately, 1 or 2 weeks. The link will appear on this page.
    #11980
    grhsc
    hello
    I saw that the Extra Scheme Components V6 version has been released, I followed the manual to install (copy under the scada folder) but when I activate here
    Instance -> Webstation->Plugins
    it has an error
    Error creating plugin interface PlgSchExtraComp of type Scada.Web.Plugins.PlgSchExtraComp.View.PlgSchExtraCompView from file C:\Program Files\SCADA\ScadaAdmin\Lib\PlgSchExtraComp.View.dll: Could not load file or assembly ‘ScadaWebCommon.Subset, Version =6.0.0.1, Culture=neutral, PublicKeyToken=null’. The system cannot find the file specified.
    https://drive.google.com/file/d/1B-OkuOS5TRz_U_AJ_VIMZOPBq5_mSt3g/view?usp=share_link
    #11982
    You should update Rapid SCADA to version 6.0.1 to use the components.
    #11986
    grhsc
    ok, thank you
    #11988
    grhsc
    Sorry I have to bother you again with this question
    I successfully updated to 6.01 and installed Extra Scheme Components without any errors, and I applied for a temporary key, it seems to have no problems,
    accroding 5.8 experience, it should be copied to the specified folder, after registration, it will appear in the Scheme editor. However, I don’t see the expected Extra Components.
    I did it again, including applying for the key, but I still can’t see the Extra Components.
    What is wrong? could yuu help me?
    #11989
    grhsc
    here is log
    Components are loaded from the file C:\Program Files\SCADA\ScadaSchemeEditor\Web\bin\PlgSchBasicComp.dll
    2023-01-19 08:59:12 <WIN10SCADAV6><win10-vm><ERR> Unable to get the plugin type Scada.Web.Plugins.PlgSchExtraCompSpec from the assembly C:\Program Files\SCADA\ScadaSchemeEditor\Web\bin\PlgSchExtraComp.dll:
    can’t from program set “PlgSchExtraComp, Version=6.0.0.0, Culture=neutral, PublicKeyToken=null” load “Scada.Web.Plugins.PlgSchExtraCompSpec”。
    PlgSchExtraComp.dll is unlocking
    • This reply was modified 3 years, 10 months ago by grhsc.
    #11992
    Thank you for finding this bug.
    Please download and update the plugin again. Now it should work in Scheme Editor also.
    Note: plugin registration is not needed for editing schemes.
    #11994
    grhsc
    My pleasure!
    #11995
    grhsc
    it’s working fine, thank you.
    #11996
    victorlam
    Can you kindly help to show some pictures about the extra scheme components for editor application?
    #12074
    The example is here.
