MikhailModeratorCould you provide more details about your task?
MikhailModeratorIn Rapid SCADA 5 it should work.Probably, you right.
In Rapid SCADA 6 currently there is no option to hide bottom panel. Should we implement such option in version 6?-
This reply was modified 2 years, 5 months ago by
MikhailModeratorCould you describe the context of the task?
December 5, 2023 at 8:54 am in reply to: Communicator Send only modified data of device tags setting #13781
MikhailModeratorIn version 6 you can enable PostgreSQL archives.
This feature I didn’t try yet, will try and see soon.By default PostgreSQL parameters are
localhost
User: postgres
Password: postgres
Database rapid_scada should be created manually.December 5, 2023 at 8:52 am in reply to: Manually update rapidSCADA under Linux, how to prevent data files from being ove #13779
MikhailModeratorAlso each application has it’s own configuration. For example, ScadaServer/Config
And keep the Views folder.-
The log file says Communicator cannot connect to the SCADA-Server service.
Also check ScadaServer.log
In general, I suggest to use Rapid SCADA 6 instead of 5.
At this moment there is no data editor to change *.dat files manually. ScadaTestClient should be used for this purpose.
For bulk data update it would be more useful to develop an application that is not format dependent and can write data to any type of Rapid SCADA archive. Like importing CSV data to a specified archive.
December 4, 2023 at 11:20 am in reply to: Communicator Send only modified data of device tags setting #13773
December 4, 2023 at 11:19 am in reply to: Communicator Send only modified data of device tags setting #13772
By default Communicator sends data on change and sends all data every minute.
But on the screenshot you disabled sending all data because period = 0.December 4, 2023 at 11:17 am in reply to: Manually update rapidSCADA under Linux, how to prevent data files from being ove #13771
MikhailModeratorOption 1
Upload the project again from Windows to Linux after update.Option 2
Copy the application files manually to keep the configuration unchanged.
Please provide screenshot of the Interface table and a web page.
Rapid SCADA 6 is recommended over version 5.
To do that, you need to specify different configuration files for different OPC servers to use different TCP ports.December 1, 2023 at 9:14 am in reply to: Issues and Error Handling When Starting a SCADA Project #13761
This topic is about building Rapid SCADA 6 from the source code. Please ask your question in a proper topic.
Find the phrases in SCADA\ScadaWeb\lang\*.xml. You can change them. Then restart a web application.
Seems like the services are not running.
First off all, check .NET as written above.
.NET version 6 is required. -
