Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › ScadaComm error
- This topic has 7 replies, 3 voices, and was last updated 2 years, 10 months ago by
January 15, 2021 at 12:42 pm #8030
Artos9
ParticipantHello,
After porting ready project from Windows to Linux server, I can’t start ScadaComm. I have an error in ScadaCommSvc.log2021-01-15 07:32:59 <shm2><root><ACT> ScadaCommService 5.2.1.2 is started
2021-01-15 07:32:59 <shm2><root><ACT> Load device library: KpSimulator.dll
2021-01-15 07:33:00 <shm2><root><ACT> Connect to SCADA-Server “testshmmonitor2.shmmonitor.com”
2021-01-15 07:33:01 <shm2><root><EXC> Error connecting to SCADA-Server: Operation on non-blocking socket would block
2021-01-15 07:33:01 <shm2><root><ACT> Disconnect from SCADA-Server
2021-01-15 07:33:01 <shm2><root><ERR> Unable to start operation due to SCADA-Server communication error.
Delay before trying again
2021-01-15 07:33:11 <shm2><root><ACT> Connect to SCADA-Server “testshmmonitor2.shmmonitor.com”
2021-01-15 07:33:12 <shm2><root><EXC> Error connecting to SCADA-Server: Operation on non-blocking socket would block
2021-01-15 07:33:12 <shm2><root><ACT> Disconnect from SCADA-Server
2021-01-15 07:33:12 <shm2><root><ERR> Unable to start operation due to SCADA-Server communication error.
Delay before trying againIn Views on Website I have Internal Server Error(500).
January 15, 2021 at 1:13 pm #8033
Likely SCADA-Server can’t start. You should check its log. Make sure that you changed server directories in the project before uploading (Server – Common Parameters).
January 15, 2021 at 1:40 pm #8034Artos9
ParticipantYou should check its log. Make sure that you changed server directories in the project before uploading (Server – Common Parameters).Yes, I change it.
ScadaServer logs.
2021-01-15 08:04:23 <shm2><root><ACT> ScadaServerService 5.1.4.1 is started
2021-01-15 08:04:23 <shm2><root><ACT> Check the existence of the data directories is completed successfully
2021-01-15 08:04:23 <shm2><root><ACT> Check the existence of the configuration database files is completed successfully
2021-01-15 08:04:23 <shm2><root><ACT> Input channels are read from the configuration database. Active channel count: 10
2021-01-15 08:04:23 <shm2><root><ACT> Ouput channels are read from the configuration database
2021-01-15 08:04:23 <shm2><root><ACT> Users are read from the configuration database
2021-01-15 08:04:23 <shm2><root><ACT> Formulas are read from the configuration database
2021-01-15 08:04:24 <shm2><root><ACT> The formulas source code has been compiled
2021-01-15 08:04:24 <shm2><root><ACT> Connection listener is started
2021-01-15 08:04:24 <shm2><root><ACT> Start server
2021-01-15 08:04:24 <shm2><root><ACT> Current data are loadedScadaServer Settings.
<ScadaServerSvcConfig>
<!–Common Parameters–>
<CommonParams>
<Param name=”TcpPort” value=”10000″ descr=”TCP port number” />
<Param name=”UseAD” value=”false” descr=”Use Active Directory for users authentication” />
<Param name=”LdapPath” value=”LDAP://server” descr=”Domain controller server path” />
<Param name=”DetailedLog” value=”false” descr=”Write detailed information to the log” />
</CommonParams>
<!–Directories–>
<Directories>
<Param name=”BaseDATDir” value=”/opt/scada/BaseDAT/” descr=”The configuration database in DAT format directory” />
<Param name=”ItfDir” value=”/opt/scada/Interface/” descr=”The interface directory” />
<Param name=”ArcDir” value=”/opt/scada/ArchiveDAT/” descr=”The archive in DAT format directory” />
<Param name=”ArcCopyDir” value=”/opt/scada/ArchiveDATCopy/” descr=”The archive copy in DAT format directory” />
</Directories>
<!–Saving Parameters–>
<SaveParams>
<Param name=”WriteCurPer” value=”1″ descr=”Current data writing period, sec” />
<Param name=”InactUnrelTime” value=”5″ descr=”Unreliable on inactivity, min” />
<Param name=”WriteCur” value=”true” descr=”Write current data” />
<Param name=”WriteCurCopy” value=”true” descr=”Write current data copy” />
<Param name=”WriteMinPer” value=”60″ descr=”Minute data writing period, sec” />
<Param name=”StoreMinPer” value=”365″ descr=”Minute data storing period, days” />
<Param name=”WriteMin” value=”true” descr=”Write minute data” />
<Param name=”WriteMinCopy” value=”true” descr=”Write minute data copy” />
<Param name=”WriteHrPer” value=”60″ descr=”Hourly data writing period, min” />
<Param name=”StoreHrPer” value=”365″ descr=”Hourly data storing period, days” />
<Param name=”WriteHr” value=”true” descr=”Write hourly data” />
<Param name=”WriteHrCopy” value=”true” descr=”Write hourly data copy” />
<Param name=”StoreEvPer” value=”365″ descr=”Events storing period, days” />
<Param name=”WriteEv” value=”true” descr=”Write events” />
<Param name=”WriteEvCopy” value=”true” descr=”Write events copy” />
</SaveParams>
<!–Modules–>
<Modules />
</ScadaServerSvcConfig>January 15, 2021 at 9:15 pm #8036Artos9
I see that ScadaWeb and ScadaServer are working still on ‘localhost’, is it correct? In case of Scada installation of my Linux server?ScadaWeb.log
2021-01-15 16:07:03 <shm2><www-data><ACT> Initialize common web application data
2021-01-15 16:07:03 <shm2><www-data><ACT> Connect to SCADA-Server “localhost”
2021-01-15 16:07:03 <shm2><www-data><ACT> Refresh the tables of the configuration database
2021-01-15 16:07:03 <shm2><www-data><ACT> Fill input channels properties
2021-01-15 16:07:03 <shm2><www-data><ACT> Fill output channels properties
2021-01-15 16:07:03 <shm2><www-data><ACT> Fill input channel statuses propertiesScadaServerSvc.log
2021-01-15 15:54:27 <shm2><root><ACT> ScadaServerService 5.1.4.1 is started
2021-01-15 15:54:27 <shm2><root><ACT> Check the existence of the data directories is completed successfully
2021-01-15 15:54:27 <shm2><root><ACT> Check the existence of the configuration database files is completed successfully
2021-01-15 15:54:27 <shm2><root><ACT> Input channels are read from the configuration database. Active channel count: 10
2021-01-15 15:54:27 <shm2><root><ACT> Ouput channels are read from the configuration database
2021-01-15 15:54:27 <shm2><root><ACT> Users are read from the configuration database
2021-01-15 15:54:27 <shm2><root><ACT> Formulas are read from the configuration database
2021-01-15 15:54:27 <shm2><root><ACT> The formulas source code has been compiled
2021-01-15 15:54:27 <shm2><root><ACT> Connection listener is started
2021-01-15 15:54:27 <shm2><root><ACT> Start server
2021-01-15 15:54:27 <shm2><root><ACT> Current data are loaded
2021-01-15 16:02:40 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:02:40 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:02:40 <shm2><root><ACT> Check username and password for admin. Result: passed
2021-01-15 16:02:45 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:02:45 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:02:50 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:02:50 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:02:55 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:02:55 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:03:02 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:03:02 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:03:09 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:03:09 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:03:40 <shm2><root><ACT> Disconnect client 127.0.0.1
2021-01-15 16:03:45 <shm2><root><ACT> Disconnect client 127.0.0.1
2021-01-15 16:03:50 <shm2><root><ACT> Disconnect client 127.0.0.1
2021-01-15 16:03:56 <shm2><root><ACT> Disconnect client 127.0.0.1
2021-01-15 16:04:03 <shm2><root><ACT> Disconnect client 127.0.0.1
2021-01-15 16:04:09 <shm2><root><ACT> Disconnect client 127.0.0.1
2021-01-15 16:06:38 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:06:38 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:06:44 <shm2><root><ACT> Check username and password for admin. Result: passed
2021-01-15 16:06:48 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:06:48 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:06:56 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:06:56 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:07:03 <shm2><root><ACT> Connect to client 127.0.0.1
2021-01-15 16:07:03 <shm2><root><ACT> The user ScadaWeb is successfully authenticated
2021-01-15 16:07:44 <shm2><root><ACT> Disconnect client 127.0.0.1
2021-01-15 16:07:49 <shm2><root><ACT> Disconnect client 127.0.0.1
2021-01-15 16:07:56 <shm2><root><ACT> Disconnect client 127.0.0.1
2021-01-15 16:08:03 <shm2><root><ACT> Disconnect client 127.0.0.1January 17, 2021 at 8:32 am #8047
MikhailModeratorI see that ScadaWeb and ScadaServer are working still on ‘localhost’, is it correct?
“localhost” means the current server. If all the apps are installed on the same server, it’s OK.
January 17, 2021 at 12:46 pm #8052Artos9
ParticipantI’m not sure, that I understand the idea.
Scada is installed on Remote Linux server (http://mywebserverexample.com/scada), as WebServer is Apache.
But additionaly Scada is configureted in cooperation with localhost.I’m sorry for misunderstanding Web&Server administrations is new for me.
December 1, 2023 at 9:21 am #13763chika
ParticipantHello Mr. Mikhail,
I had a scada communicator error problem, then I tried to run the “Hello world” project but it also didn’t work.
https://drive.google.com/file/d/1H6bTrWVkFmA3d-uNh4iDgRU0sGN7KtOl/view?usp=drive_link
help me please.
thank youDecember 4, 2023 at 11:25 am #13775
The log file says Communicator cannot connect to the SCADA-Server service.
Also check ScadaServer.log
In general, I suggest to use Rapid SCADA 6 instead of 5. -
