Viewing 15 posts - 4,891 through 4,905 (of 6,266 total)
  • in reply to: Source Code KpOpc.dll #3476
    Thanks a lot!
    Could you create a release on the GitHub repository and put there the necessary DLLs? Like here
    What is the current state of the development? Is it ready enough to be used by the users?
    in reply to: OPC Server Connection – E_NETWORK_ERROR #3475
    In this case, if it’s possible, we should contact with the OPC server developers and works with the to fix the issue. I can assist you in email conversation. We did the same thing to fix another OPC server for BACnet (I forgot its name).
    in reply to: Bound Server Problems #3471
    Thank you for the status info.
    in reply to: OPC Server Connection – E_NETWORK_ERROR #3470
    Oh, did you install OPC Core Components? They are required.
    in reply to: arduino #3464
    Duplicated here
    in reply to: ModDBExport #3460
    Do you know that you can simulate sending data by the Generator function of the Server app? May be it helps. Also you can write simple application that sends data to Server. I can assist a bit here.
    in reply to: ModDBExport #3459
    in case new data are the same as old data, there are no new data or are not written as the values for SQL Instruction
    To fully understand your task, I have to do a research. This is not a part of free support. I can reproduce a simple example, and if it doesn’t work as expected, fix it. Also I can explain how Rapid SCADA works.
    Another option is connecting to your machine remotely and find out the cause of the problem. This is a commercial service.
    I hope I can help you in a one form or another.
    Anyway, I think I understand what you are talking about. How would you like the software to work to make your task clear without tricks? Should Communicator send all data, that were read, after each communication session?
    in reply to: OPC Server Connection – E_NETWORK_ERROR #3458
    Try this utility to test https://yadi.sk/d/d1UOUw153DcoDp Does it work?
    When does E_NETWORK_ERROR occur?
    The OPC server also can be the cause of the problem. For example, we contacted with a developer on a one OPC server to append the proper implementation of all needed OPC methods. When he does it, connection was OK.
    in reply to: Some problems #3455
    I think, it is possible to create a component for schemes that can show IPcam in a popup window over a scheme.
    in reply to: ModDBExport #3454
    Why you don’t use hardware modules that counts off/on cycles? This would be much reliable and transparent.
    in reply to: ModDBExport #3453
    procSrez = curSrez;
    Save the reference to a snapshot which is processed.
    // вычисление новых данных входного канала
    Calculate new data of the input channel
    in reply to: Source Code KpOpc.dll #3452
    It would be good if you post here a link to your repository.
    in reply to: No library found for component #3451
    We should activate it by default.
    in reply to: ModDBExport #3440
    Could you open the code you interested in by GitHub and copy link to a particular line of code? Of course, I will help to understand.
    What happens if PC is off? Do you loose some switching?
    in reply to: Some problems #3439
    Do you ask me about the web page path to specify in the command?
