Forum Home › Forums › Understanding the Software › No library found for component
- This topic has 6 replies, 3 voices, and was last updated 8 years, 3 months ago by
April 9, 2018 at 9:15 am #3434
catcute
ParticipantHi Mikhail
I make a scheme with Toggle and Led component, then in web application, it return the error at below:
Can you give me any suggesstion?April 9, 2018 at 12:12 pm #3437
Please check the log of the web application.
Do you know where to find it?April 10, 2018 at 2:14 am #3446catcute
I checked Web log( hope correct!), but i can not find out problem.2018-04-10 09:06:21 <HN3521><DefaultAppPool><ACT> Initialize common web application data
2018-04-10 09:06:21 <HN3521><DefaultAppPool><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgChartPro.dll:
Could not load file or assembly ‘file:///C:\SCADA\ScadaWeb\bin\PlgChartPro.dll’ or one of its dependencies. The system cannot find the file specified.
2018-04-10 09:06:21 <HN3521><DefaultAppPool><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgDashboard.dll:
Could not load file or assembly ‘file:///C:\SCADA\ScadaWeb\bin\PlgDashboard.dll’ or one of its dependencies. The system cannot find the file specified.
2018-04-10 09:06:21 <HN3521><DefaultAppPool><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgElasticReport.dll:
Could not load file or assembly ‘file:///C:\SCADA\ScadaWeb\bin\PlgElasticReport.dll’ or one of its dependencies. The system cannot find the file specified.
2018-04-10 09:06:22 <HN3521><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2018-04-10 09:06:22 <HN3521><DefaultAppPool><ACT> Refresh the tables of the configuration database
2018-04-10 09:06:23 <HN3521><DefaultAppPool><ACT> Fill input channels properties
2018-04-10 09:06:23 <HN3521><DefaultAppPool><ACT> Fill output channels properties
2018-04-10 09:06:23 <HN3521><DefaultAppPool><ACT> Fill input channel statuses properties
2018-04-10 09:06:23 <HN3521><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: sriqvuhtyumvpbivzxbrnndb
2018-04-10 09:06:37 <HN3521><DefaultAppPool><ACT> Login: admin (Administrator). IP address: ::1
2018-04-10 09:06:37 <HN3521><DefaultAppPool><ACT> User information has been updated. IP address: ::1. Session: sriqvuhtyumvpbivzxbrnndb
2018-04-10 09:06:38 <HN3521><DefaultAppPool><ACT> Retrieve components from the installed plugins
2018-04-10 09:11:04 <HN3521><DefaultAppPool><ACT> Logout: admin. IP address: ::1
2018-04-10 09:11:04 <HN3521><DefaultAppPool><EXC> Error getting extended current data by the filter where channels= , view id=18:
Scada.ScadaException: User not logged on.
at Scada.Web.UserMonitor.CheckLoggedOn(UserRights& userRights, Boolean throwOnFail)
at Scada.Web.ClientApiSvc.GetCurCnlDataExt(String cnlNums, String viewIDs, Int32 viewID)
2018-04-10 09:11:05 <HN3521><DefaultAppPool><ACT> Login: admin (Administrator). IP address: ::1
2018-04-10 09:11:05 <HN3521><DefaultAppPool><ACT> User information has been updated. IP address: ::1. Session: sriqvuhtyumvpbivzxbrnndb
2018-04-10 09:11:05 <HN3521><DefaultAppPool><ACT> Retrieve components from the installed pluginsApril 10, 2018 at 2:56 am #3447catcute
Problem come from that I’ve not active Basic scheme components plugin yet! :))April 10, 2018 at 12:01 pm #3451
We should activate it by default.April 22, 2018 at 3:44 pm #3577jacklondon
Where do we activate the new components plugin?
This reply was modified 8 years, 3 months ago by
jacklondon.
April 23, 2018 at 6:43 am #3587
Open the web app, click Main Menu – Plugins – Installed
http://localhost/Scada/plugins/Config/Plugins.aspx -
