I have already setup successfully 2 TCP connections so far. In both case Rapid Scada was client and other devices was setup as tcp servers. Now i imported 3rd device same as before (setup as device server) All 3 devices have own communication line in communicator, own input channel numbers (i pay attention to not overlap input channel numbers). I setup everything so Scada see 3 separate devices.
Then i find problem that i have with 3rd device. When i check bound to server option you don’t see any value that scada read plus communication status says not establish.
I see corresponding input channel numbers but can’t see any value.
In the communication line log i saw Incorrect MBAP header data.
If you turn off bound to server.
You see value from device but then i don’t see input channel numbers. I understand its normal to not see input channels because you turn of bound option but i can’t understand where is the problem.
