Forum Home › Forums › Uncategorized Issues › Some problems
- This topic has 9 replies, 3 voices, and was last updated 8 years, 3 months ago by
March 28, 2018 at 8:24 am #3371
leon
ParticipantHi.
1.
ScadaSchemeEditor WNI7 Missing components(Basic)
https://imgur.com/a/h0Umd2.
Send a command type 1 (binary) to open a web page(IP examples:192.168.X.X)3.
Can email be sent via virtual account(IP)?-
This topic was modified 8 years, 3 months ago by
leon.
March 28, 2018 at 9:24 am #3374syndrome5
ParticipantFor the number 1, I think it’s because the Github version and the last Release are not the same. But if you say that you download on both system with the same way, I don’t know, maybe RapidScada try to use some Windows DLL but when it doesn’t find them it goes over.
March 28, 2018 at 5:01 pm #3382
1. Check the log file in C:\SCADA\ScadaSchemeEditor\Log
Do you use the same versions of the applications? Did you install the Webstation app on Win7 (this is important)?2 and 3. Could you explain more detailed?
March 28, 2018 at 5:02 pm #3383
MikhailModeratorI can see in the screenshot that the Editor versions are different.
March 29, 2018 at 2:25 am #3385leon
Participant1.
Re-install scada_5.5.1 problem solved!
2.
Receive data from PLC (binary) such as gate position(open/close) to open ipcam web page.
3.
Use IP(mail server) with ScadaCommCtrl send mail.March 29, 2018 at 6:53 pm #3395
MikhailModerator2. Any web page is opened by a user click. This is a bad approach to open a web page accidentally.
3. You can use different web servers that support SMTP.
April 9, 2018 at 8:31 am #3433leon
Participant2.
Can receive data from PLC (binary) send to PC(command: start chrome.exe http://192.168.1.1XX) to open web page?3.
Solved!April 9, 2018 at 12:16 pm #3439
MikhailModeratorDo you ask me about the web page path to specify in the command?
April 10, 2018 at 6:12 am #3448leon
ParticipantIs it possible to send command to open web pages via RAPID SCADA?
Received the door position(open/close) signal to the PLC
By RAPID SCADA send command to the PC
To open the web(ipcam monitor screen)
https://imgur.com/a/57uuMBecause I use a translator to talk to you
Please bear with me Thank you!-
This reply was modified 8 years, 3 months ago by
leon.
April 10, 2018 at 12:15 pm #3455
MikhailModeratorI think, it is possible to create a component for schemes that can show IPcam in a popup window over a scheme.
