Forum Home › Forums › Communicating with Devices › Modbus › arduino
- This topic has 25 replies, 8 voices, and was last updated 8 years ago by
ArnyLogan.
December 11, 2017 at 11:02 am #2931
franperales1
ParticipantHi. I have successfully installed rapid scada in windows 10. I can make an application to connect with mega arduino. what libraries should I add to arduino to communicate with rapid scada.
There is someone in the forum who has something about it.
There is a tutorial to create a new project based on arduino.
Thanks in advance.
a greetingDecember 11, 2017 at 6:03 pm #2934
In simple case you can implement it without libraries: https://github.com/2mik/arduino-2mikFebruary 14, 2018 at 6:37 am #3160jirex27
ParticipantHi there,
I am developing an automated building system and I am using RAPIDSCADA for monitoring purposes. Can you help me through with it? Like I have two PIR sensors which light two LEDs respectively according to the signal and similarly a LM35 sensor to start a relay. How do I go along with it? And how do i upload MODBUS RTU to the arduino?February 14, 2018 at 8:08 am #3162
MikhailModeratorI can help you with Rapid SCADA. I am not a master of Arduino. I heard there are existing implementations of Modbus for Arduino.
February 16, 2018 at 5:46 am #3171jirex27
ParticipantCan you help me or provide information about the implementations?
February 16, 2018 at 5:47 am #3172jirex27
ParticipantI’m familiar with the arduino programming. I need help with the communication between RAPIDSCADA and Arduino.
February 16, 2018 at 12:40 pm #3177
MikhailModeratorIf Arduino is programmed to support Modbus, you can connect it to Rapid SCADA. See http://doc.rapidscada.net/content/en/use-cases/modbus-protocol.html
February 22, 2018 at 9:58 am #3210manraj
ParticipantHi there!
I am building a pipeline project using RAPID SCADA.I would need to connect some pressure sensors to an arduino and the arduino would need to be connected to the SCADA cloud monitoring.Could you suggest me the typical arduino board and its sensors that is compatible to RAPID SCADA.
February 22, 2018 at 5:55 pm #3211
If your Arduino supports Modbus, it can be connected to Rapid SCADA. See the boards here https://www.arduino.cc/ They are all goodFebruary 23, 2018 at 2:54 am #3215manraj
ParticipantCan this support Modbus because it is integrated with TCP.Does that means it can support Modbus.
February 23, 2018 at 10:34 am #3216
MikhailModeratorLikely. Depends on the sketch you upload to it.
April 11, 2018 at 6:33 am #3461AHI 633
ParticipantHi every body
I have a problem with Rapid SCADA configuration , software was installed in windows 10 but communicator does not popup when trying to configure communication with device …
urgent help is appreciated
thank you allApril 11, 2018 at 11:42 am #3464April 12, 2018 at 10:18 pm #3482Pieter
ParticipantApril 12, 2018 at 10:21 pm #3483Pieter
Participant -
