If you can’t fix it by yourself, be free to ask.
MikhailModeratorNo programmatic limits. You should check performance of your real system.
Despite of Communicator settings, all input channels have double data type. You should search for the cause in Communicator.
MikhailModeratorUseful, thank you 🙂
MikhailModeratorHi José,
I recommend Notepad++ for editing XML. WordPad may corrupt them. You can download Notepad++ from https://notepad-plus-plus.org/
You should check C:\SCADA\ScadaSchemeEditor\Log\ScadaSchemeEditor.log for error details.
Before you send the files to me, try to check them by yourself. I can help you to understand meanings of error messages.
That would be great!
I fixed the error related to Communicator. Download Language Pack again, please.Talking about Scheme Editor, the file ScadaSchemeEditor\Lang\ScadaSchemeEditor.es-LA.xml is outdated. You have 2 options:
1. The best is creating a new translation for Scheme Editor.
Copy ScadaSchemeEditor.en-GB.xml to ScadaSchemeEditor.es-LA.xml. Then open it and translate the phrases. When it is tested, you could send me the file to include in the pack.2. Delete ScadaSchemeEditor.es-LA.xml and use the editor in English.
It means that IIS doesn’t work. You should check the installed components. Also check the port 80, may be it is used by another application.
What is displayed by http://localhost/ ?
MikhailModeratorI had executed the svc_install.bat from the command line as administrator above is the screenshot.
The error: not enough privileges. Run command line as administrator.
Please type a culture as an argument
The command is:
SetCulture.exe en-GB
MikhailModeratorI added the driver to the repository http://demo.rapidscada.net/plugins/Store/Store.aspx
Keep us up-to-date about the changes please.
MikhailModeratorYou can download the updated version using this link https://rapidscada.org/download/lang_pack/lang_pack_1.3.zip
MikhailModeratorYou have to define commands in the Modbus template. See Commands tree node.
