Button
  • #3567
    Joao_Pereira
    I have seen this topic Button object but I cant get it to work.
    I want to turn a Modbus Coil On, where in RapidScada I say which coil I want to turn On?
    So far I have:
    -> DynamicPicture:
    – Action: Send command
    – Input channel: 0
    – Output channel: 1
    -> SCADA Administrator:
    – Input Channel
    https://imgur.com/a/TYRGQh7
    – Output Channel
    https://imgur.com/a/3UDVYND
    • This topic was modified 8 years, 7 months ago by Joao_Pereira.
    • This topic was modified 8 years, 7 months ago by Mikhail.
    #3590
    Check log of Communicator. Does it receive your command?
    In the new version of Rapid SCADA, you can also use Button component. But Dynamic Picture is OK too.
    #3605
    Joao_Pereira
    Thanks for the help, in Log I got this message when I click in the picture:
    The device does not support sending commands
    But I dont know how to fix it.
    #3610
    You should find the cause in Communicator.
    Can you provide links to screenshots of Communicator settings?
    #3611
    Joao_Pereira
    This are the settings that I think you ask for, if this prints isn’t enough please tell me. And thanks for you fast replay.
    https://imgur.com/GOOHjHU
    https://imgur.com/ULIxIq8
    https://imgur.com/bO5KR5q
    • This reply was modified 8 years, 7 months ago by Mikhail.
    #3613
    You have to define commands in the Modbus template. See Commands tree node.
    #3629
    Joao_Pereira
    Thanks! I works now 🙂
