MikhailModeratorWindows 8 has no future. To use with Rapid SCADA Windows 10 is better than 8.
but there is no “scada” folder in there
You copy the scada directory.
You need only one output channel. Set the Command Values field to “Execute”, set Command Type to Binary and enable Formula used.
Set the formula:
new byte[] { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08 }Check how it works, and what are the register values sent as a result. Copy here communication log, containing the command.
This reply was modified 5 years, 2 months ago by
A user can input only one value in the command dialog. It’s possible to send 2 values using formulas. What is the meaning of this command for a user? Is it possible to simplify input for him? For example, a user just click “Execute” and the predefined values are sent to controller.
MikhailModeratorHi Rich,
If it happens again and you find a particular cause, please share info with us.
A utility should be developed to import data. Otherwise, only manual input one by one value is available.
MikhailModeratorfound server interface database not get updated to reflect configuration change
Please provide more info:
1. Which changes.
2. What module or plugin does not update the changes.
Problem like this is difficult to diagnose. Did you check CPU and memory load in Device Manager?
May be the problem is related to network configuration. I mean if web requests go by wrong routes. Please also check network adapters: do you have virtual adapters created by other applications?
MikhailModeratorMost of Linux users install Rapid SCADA on Debian or Ubuntu. If you have no special Linux experience, Windows is easier. Windows 10 is preferred.
Agent was already installed.
but stll can’t connec’t to Web station (Server is unavailable)
You should start a new topic because this issue is not about installation.
You should delete C:\SCADA\Projects and install only Administrator again. The other applications are installed.
MikhailModeratorLog files are C:\SCADA\ScadaServer\Log\ModRapidGate*.log
Try installing the up to date version of KpMqtt.dll. May be it doesn’t fix the error, but the new version provides the detailed error message (link).
MikhailModeratorDoes it shown even if your project is deployed on the same machine?
MikhailModeratorIn windows there is the virtual keyboard, it works quite well, but it is not very dynamic with text boxes.
If switch Windows to tablet mode, the keyboard will show automatically.
The integration of the virtual keyboard within the data boxes in RapidScada would really be very good.
Just ideas of course, I understand that everything is a lot of work and time.Virtual keyboard plugin is a good idea. Such specialized tasks usually are developed by a custom contract, and then we share it for everyone as a plugin.
