Administrator icon not show in Menu tap
Forum Home › Forums › Installation Issues › Administrator icon not show in Menu tap
  • #7947
    Omega3.1
    Dear sir
    I have some error text between software install process, After finished in SCADA menu (Start/Program menu) don’t found Administrator icon and Web station can’t connected
    #7948
    Omega3.1
    Rapid SCADA 5.8.2 Installation
    Create directory C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SCADA
    Install Server application
    Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaServer.zip
    Install service ScadaServerService
    Installation of Server application has completed successfully
    Install Communicator application
    Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaComm.zip
    Install service ScadaCommService
    Installation of Communicator application has completed successfully
    Check the configuration of Internet Information Services (IIS)
    Check Windows Communication Foundation (WCF)
    Register ASP.NET
    Install Webstation application
    Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaWeb.zip
    Selected application pool: DefaultAppPool
    Register web application Scada
    Create shortcut Webstation
    Installation of Webstation application has completed successfully
    Install Agent application
    Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaAgent.zip
    Install service ScadaAgentService
    Installation of Agent application has completed successfully
    Installation of Administrator application has completed with a error:
    Directory C:\SCADA\Projects has to be cleared
    Install Scheme Editor application
    Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaSchemeEditor.zip
    Installation of Scheme Editor application has completed successfully
    Install Table Editor application
    Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaTableEditor.zip
    Installation of Table Editor application has completed successfully
    Installation has completed with errors
    Please restart the computer
    #7952
    You should delete C:\SCADA\Projects and install only Administrator again. The other applications are installed.
    #7955
    Omega3.1
    Hi, Mikhil
    Thanks for your advice, I can install and open Administrator icon but stll can’t connec’t to Web station (Server is unavailable)
    After finished installation show as below detai;
    Process completed with an error
    Installation of Agent application has completed with a error:
    Service ScadaAgentService hasn’t been installed
    Regards,
    Wanchai P.
    #7956
    Agent was already installed.
    You should start a new topic because this issue is not about installation.
    #7959
    Omega3.1
    Okay
    Thanks,
    Wanchai P.
