Mobile resolution or view
Forum Home › Forums › Development and Integration › Mobile resolution or view
  • #17794
    quintelosky
    Hi everybody
    Can the program detect whether it is being viewed from a mobile device or a computer and load one view or another accordingly?
    The reason is that the view, having a fixed resolution, appears very small on mobile in vertical orientation (you have to rotate it), but most people use it vertically.
    What other option would there be?
    #17795
    As far as I know, no. I made a mnemonic specifically for the vertical version of a mobile device and created a second user specifically so that they could connect from a mobile device. Then he scored 🙂
    #17796
    quintelosky
    Many thanks
    Yes, I had thought about doing the same.
    #17797
    A variation on the same idea:
    1. Deploy a separate instance of the web application for mobile users.
    2. Add views for mobile in a different folder.
    3. Set a corresponding start view for mobile users in the web app settings.
