Viewing 15 posts - 2,956 through 2,970 (of 6,219 total)
  • in reply to: OPC on Remote PC #8910
    You also could watch this video about OPC UA configuring.
    in reply to: OPC on Remote PC #8909
    Please provide more details of you task.
    OPC DA and OPC UA are supported by different Rapid SCADA drivers, and they are configured differently.
    in reply to: Cant even login Raspberry Pi 4B Ubuntu 21.04 #8908
    Does raspbian differ from Ubuntu in the process?
    If you mean the process of Rapid SCADA installation, it’s similar.
    in reply to: scheme editor #8897
    Align feature will be added, because it’s really needed.
    Thank you for additional notification about that.
    You need:
    1. Specification of the communication protocol between computer and the transmitter.
    2. Develop a driver (.NET assembly, C# language) that implements that communication protocol.
    in reply to: Change event type color #8895
    When enumeration includes 2 values, colors always red (0) and green (1).
    Just add any 3rd value of the unit.
    Are there channels 9602 and 9603 in the screenshot or others?
    in reply to: 65535 limit #8894
    You should create a new topic, because the subject of the current topic is different.
    in reply to: Developer in India #8887
    Maybe you should train your Rapid SCADA engineers and become our partner in India.
    in reply to: 65535 limit #8886
    How should I change the source code?
    It would be a huge change of source code. Otherwise, we got rid of this limit long ago.
    The v6 will support more channels.
    in reply to: How to get string value from Database #8876
    If string values are static, it’s possible to return a number from SQL request and then display it as a string (for example, Off and On values).
    in reply to: How to get string value from Database #8875
    it seems only a few characters is obtained, not the whole string value
    It supports 8 Latin characters per input channel.
    Actually this statement would get a result set,but only the first record is shown, the following records are missing.
    You right. The idea of the driver is to get a single row of current data.
    If you need to update the existing driver to be able to get data from a row set, we could discuss the requirements and cost.
    in reply to: Communication Line bound to server signal limitation #8874
    Thank you for the info.
    the signals sent to server seems to be uncertain when the limit is exceeded.
    It’s because of integer overflow. 5001 signals would send 319 items.
    in reply to: Views #8866
    Hi Matt,
    Thanks for the images. Interesting case.
    Probably, it’s needed to add a home folder with ID = 1. And the Overview scheme is inside the home folder with ID = 2.
    We should implement a possibility to move a tree node as you shown in the future.
    in reply to: MQTT #8865
    if we can solve problem with formulas and events there is plan to test on some real project where SCADA would be accessible from outside our LAN and we would monitor location in some other company
    Nice. I’m sure that all the mentioned issues can be solved. And I’ll help.
    in reply to: MQTT #8864
    About performance:
    Please wait a bit when we upload the driver update. The update will provide more details about received topics in the log.
    Then we should compare the driver with another MQTT client that is installed on the same machine as Communicator and subscribes the same set of topics.
