Change event type color Forum Home › Forums › Understanding the Software › Change event type color This topic has 4 replies, 3 voices, and was last updated 2 years, 10 months ago by kcks66. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts May 9, 2021 at 6:39 am #8890 kcks66Participant Hi Mikhail, Good day to you. I created a new UNIT as below. https://ibb.co/tp0Scwx I got the UNIT name as my expectation. However, I wish to change their EVENT color: OK == Green NG == Red https://ibb.co/TWn7Zjh Pls advice for how I can change their color. Thanks. May 9, 2021 at 7:05 am #8891 manjey73Participant Configuration Database-Directories-Event types Add your event and specify your color, or use the ones that are there In the input channel 177, use a formula like this Val();Val()>0? SetStat(177,116):SetStat(177,117) In this way, you change the channel status number to your own, to which the colors are linked. May 9, 2021 at 8:48 am #8893 kcks66Participant Hi manjey73, I tried as your advice. https://ibb.co/DQgR9sr https://ibb.co/275kmrx However, the event status color still remain unchanged. Pls advice and thank you. May 9, 2021 at 9:11 am #8895 MikhailModerator Hi, When enumeration includes 2 values, colors always red (0) and green (1). Just add any 3rd value of the unit. Are there channels 9602 and 9603 in the screenshot or others? May 11, 2021 at 12:54 am #8919 kcks66Participant Hi Mikhail, It is worked after I added 3rd value of the unit. Thank you. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
