65535 limit Forum Home › Forums › Understanding the Software › 65535 limit This topic has 3 replies, 2 voices, and was last updated 5 years, 5 months ago by Mikhail. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts May 6, 2021 at 11:36 pm #8880 ZeusParticipant hi I am curious why there is a limit 65535 on version V5. if I want to use it without limit. How should I change the source code? May 7, 2021 at 1:42 pm #8886 MikhailModerator Hi, How should I change the source code? It would be a huge change of source code. Otherwise, we got rid of this limit long ago. The v6 will support more channels. May 8, 2021 at 1:53 am #8888 ZeusParticipant Hi, I got a problem. I am trying to config input channels. The type of channel is calculated real. I checked event and event onchange. But there is no event triggered on the webstation. https://ibb.co/fdq9tfg the count of input channels is 19900. whether or not it is the reason that caused the problem. May 9, 2021 at 9:07 am #8894 MikhailModerator Hi, You should create a new topic, because the subject of the current topic is different. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
