MQTT
Viewing 14 posts - 1 through 14 (of 14 total)
  • #8753
    Jure
    I have problem with MQTT. I can connect to broker with client, but Rapid SCADA communicator is reporting error:
    http://imgur.com/a/xyEmb84
    I tried different settings, but I don’t know what else can I try.
    #8758
    First, try to connect public MQTT broker according to the video. Does a public broker works or not?
    The MQTT driver is difficult to diagnose.
    #8846
    Jure
    From the last time I was able to make MQTT working. Data and commands are successfully transferred. But I have another question. Is it possible to use formulas for input channels that are using MQTT? Or should I use formulas inside mqtt.xml file? And how is with events and alarms?
    #8847
    Jure
    Now one formula is working, but it doesn’t execute just once, but whole time. So – operator works, but / doesn’t work.
    http://imgur.com/a/dReUchm
    I hope that you can see all three images: device, channels and web browser view.
    • This reply was modified 5 years, 3 months ago by Jure.
    #8850
    Formulas are processed on the Server application level and they do not depend on a driver.
    The result of formulas can be displayed by views, not in Communicator.
    #8855
    Jure
    As you can see on my images I have two formulas:
    Cnl – 10
    It looks like it is done on each cycle of program. Because of that value gets lower on each cycle.
    Cnl / 10
    This formula is never caluclated. Value is all the time the same as in communicator.
    #8856
    Jure
    I also noticed that Rapid SCADA takes quite some time to read data from Mqtt broker. When around 80 variables is published to Rapid SCADA it takes more then 1 minute to show all the data.
    If I send command from Rapid SCADA -> PC -> PLC communication is much faster.
    If we choose Rapid SCADA for our projects can we count on official support or is Mqtt community developed and so unofficial?
    #8857
    I don’t see any images that contains formulas. If you add them, I will check.
    As wrote above, the result of formulas can be displayed by views, not in Communicator.
    Could you provide more info about that?
    We also support the existing MQTT driver.
    #8858
    Note: the MQTT driver update is coming soon. The driver will support generating of input channels according to the configuration, and JSON parsing will be improved.
    #8862
    Jure
    Is imgur working OK for you? Because above I see one image view where if you move right or left you can swap images so in total are 3.
    This is image with formulas:
    http://i.imgur.com/SEZpypc.png
    As you can see, all that I do is Cnl / 10 and Cnl – 10.
    I know that you can see result of formulas, that is why there is also image of view. You can see in event log that formula is used multiple times per second, so probably is used on every program iteration:
    http://i.imgur.com/y8fNCxn.png
    I am not sure what more info I can give, I will try to describe process in more details. I have two computer and PLC in same LAN.
    Mqtt PC: It runs Mqtt client that is based on Mqtt Paho Java
    Server PC: It runs SCADA and Mqtt broker
    PLC from where we read values and change them
    1. Rapid SCADA is running.
    2. I start mqtt client.
    3. Mqtt client retrieves values and updates topic values. I don’t use .js just plain topic values.
    4.Mqtt broker acknowledges new topic values and publishes them to Rapid Scada. Like I said in short time there are around 80 topics published. It can take up to 1 minute or probably even more for communicator to update all values.
    I tried with just on topic and it can take from 4-10 seconds for topic to be updated in communicator.
    That is great. Currently we made all of the testing in the office and SCADA was accessible just in LAN. But if we can solve problem with formulas and events there is plan to test on some real project where SCADA would be accessible from outside our LAN and we would monitor location in some other company.
    #8863
    About the formulas:
    You should change channel type to “Real”. In this case, formulas are calculated when new value is coming from a controller or MQTT broker.
    #8864
    About performance:
    Please wait a bit when we upload the driver update. The update will provide more details about received topics in the log.
    Then we should compare the driver with another MQTT client that is installed on the same machine as Communicator and subscribes the same set of topics.
    #8865
    Nice. I’m sure that all the mentioned issues can be solved. And I’ll help.
    #9060
    Jure
    EDIT: Nevermind i think that I found error.
    • This reply was modified 5 years, 2 months ago by Jure.
