Forum Home › Forums › Development and Integration › Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver?
- This topic has 12 replies, 2 voices, and was last updated 2 years, 11 months ago by Mikhail.
May 8, 2021 at 8:17 am #8889hethongscada62Participant
Dear Mr.Mikhail,
I am now testing to send code of RF transmitter 315MHz to RF receiver on my project using Rapid Scada. I known by Internet that the RF transmitter 315MHz has three methods to send raw codes:
1) Binary string
send(string binaryCode)
2) Decimal value
send(int decimalCode, int bitLength)
3) Tri-state string
sendTriState(string triStateCode)
So Pls let me know:
– Can the rapid scada send these codes?
– Which method?
– How to configure if the Rapid Scada can send them?
Thanks and best regards
From Han HoangMay 9, 2021 at 9:14 am #8896MikhailModeratorHello,
You need:
1. Specification of the communication protocol between computer and the transmitter.
2. Develop a driver (.NET assembly, C# language) that implements that communication protocol.May 10, 2021 at 1:36 pm #8913hethongscada62ParticipantDear Mr.Mikhail,
Thank you for your reply.
I am not IT developer, so i can not create a driver but i have had a another solution. Are you going to develop it?
ThanksMay 11, 2021 at 12:52 pm #8931MikhailModeratorHello,
Is the transmitter manual available?
May 11, 2021 at 3:03 pm #8936hethongscada62ParticipantDear Mr.Mikhail,
Yes, the transmitter can be manual available. I am using an Arduino as intermediate driver, so i can control a transmitter via Button on Rapid scada Web to send codes.
But the better is having a driver, ins’t it?
ThanksMay 12, 2021 at 2:04 pm #8938MikhailModeratorHello,
It’s better if you draw a diagram of the system, and show which communication protocols are used on different architecture levels.
May 12, 2021 at 3:10 pm #8940hethongscada62ParticipantDear Mr.Mikhail,
The diagram of the system is sample: replacing a Buttons on RF(or IR) remote controller (garage door, lights, fan,…) by Buttons on Web rapid scada .
For example: The EV1527 chipset in garage door remote uses a 24-bit codeword comprising 20 address bits followed by 4 data bits. The codes have been got from garage door remote are:
Button 1:
Decimal: 8571080 (24Bit)
Binary: 100000101100100011001000
Tri-State: not applicable
PulseLength: 321 microseconds
Protocol: 1
Raw data: 9964,956,332,312,976,312,976,308,980,304,980,308,980,952,340,304,980,956,336,188,908,276,728,264,124,168,308,60,24,60,236,88,88,204,88,76,80,56,1020,284,440,56,24,40,100,84,12,36,56,Button Address Data
Button 1: 10000010110010001100 1000
Button 2: 10000010110010001100 0100
Button 3: 10000010110010001100 0010
Button 4: 10000010110010001100 0001
So can create a driver that sends commands with above data from Rapid Scada directly to RF (or IR) Transmitter part?
ThanksMay 13, 2021 at 12:59 pm #8948MikhailModeratorHello,
An I understand you correct:
When a button in Rapid SCADA is clicked, you need to send a static predefined sequence of bytes? And no response from device to Rapid SCADA?May 14, 2021 at 1:47 am #8950hethongscada62ParticipantDear Mr.Mikhail,
The sending a static predefined sequence of bytes when a button in Rapid SCADA is clicked have been worked, but not response from device. I think there was the problem with PulseLength. Have to create something likes as a driver or formula?
Thanks a lotMay 14, 2021 at 1:05 pm #8952MikhailModeratorHello,
For the current moment I don’t understand how Rapid SCADA should behave according your task.
May 19, 2021 at 1:57 pm #8969hethongscada62ParticipantDear Mr.Mikhail,
My Rapid Scada project is running well now. It can control my devices via RF transmitter.
It is sample. Rapid scada can control devices via Outs as relay. This relay control the Input of RF transmitter. That’s all. You can see my screenshot. Rapid Scada can control all devices at my home. Rapid Scada is great.
https://ibb.co/nD4XfgR
There is bad that have to use many relays.
Thank You for your attention.
Han HoangMay 19, 2021 at 2:03 pm #8970hethongscada62ParticipantSorry.
This is screenshot is true.
https://ibb.co/dfkqg5H
Thank You againMay 20, 2021 at 1:00 pm #8975MikhailModeratorHello,
The screenshot looks pretty good. Thank you for the appreciation of our work.
Do you have any questions at the moment? -
