Viewing 15 posts - 1,156 through 1,170 (of 6,389 total)
  • in reply to: TCP/IP Problem #14695
    Usually 4G modems are not available by IP from outside. Telecom operators sell white IP addresses. Another solution is using VPN.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #14687
    The above advice is correct.
    @arunruchir
    , could you provide screenshots of the settings and device data page?
    • This reply was modified 2 years, 4 months ago by Mikhail.
    in reply to: Error: Garbage collecctor… #14686
    Looks like an out of memory error. How long does it work after rebooting the Raspberry?
    In general, I recommend to upgrade to Rapid SCADA 6 which uses modern .NET framework.
    in reply to: TCP Server Connection Issue #14685
    As I remember Moxa NPort has such settings, for example.
    in reply to: Historical data report achieve copy #14684
    No, I mean changing only the Kind cell to empty value.
    in reply to: Historical trends #14683
    Also Dashboard Plugin can be useful.
    in reply to: Historical trends #14682
    You can display Chart Pro as a view page. Check this link.
    in reply to: Logging Data per second #14671
    Still got “Access denied”.
    To check that, open the link in another browser without Google sign in.
    in reply to: Show last input value on restart #14670
    public CnlData KeepGoodData()
      return CnlStat > 0 ? NewData(Cnl, CnlStat) : Data();
    in reply to: Communication status when no connection #14669
    To store last communication time, you need to create a new channel, and develop a formula that stores the time in that channel.
    Keeping last good value can be done by the formula.
    in reply to: TCP Server Connection Issue #14667
    In TCP communication, a connection brakes silently sometimes. If a client cannot poll a server, it must reconnect if there is no reply or connection is idle for a period.
    in reply to: Historical data report achieve copy #14666
    May be change their archive kind to empty in the Archives table.
    Does it help?
    in reply to: Sum of Channels #14664
    In a formula you can check values of other channels. So you should add a function to the Scripts table, and then use that function in a channel formula.
    I will not write the formula for you, because writing complex formulas is a paid service, but I can help to solve the related questions.
    in reply to: Logging Data per second #14658
    Currently access by the above link is denied. Please make it public.
    in reply to: Logging Data per second #14651
    Dear Arya,
    I suggest to add a new archive in the Archives table and in the Server settings.
    This archive should not be default. Set archive mask for channels that will be written in the archive.
