web station bug
Forum Home › Forums › Runtime Bugs › Webstation Bugs › web station bug
  • #13928
    Zeus
    After clicking to enlarge the interface, width adaptation will be performed, resulting in horizontal and vertical scrollbars and blank areas
    #13930
    Zeus
    Zeus
    This situation occasionally occurs
    #13934
    What buttons should I click to reproduce the issue?
    #13942
    Zeus
    Press the zoom button and the horizontal stretching button
    https://ibb.co/vk7VQr7
    #13944
    I kind of showed something like this, scrollbars appear when switching, although in principle they should not.
    #13950
    Can you reproduce this issue on https://rapidscada.net/scada/ ?
    If your page is available online, I can check.
    #13957
    Zeus
    There is nothing wrong in this website.
    I found that when I click on the collapse menu and then click on the expand menu, a scrollbar will also appear after a while it will trigger a re rendering method. The scrollbar will disappear.
    In version 6.1.6, there is no re rendering action.
    #13962
    Possibly, a scheme size may be the cause of the issue. If your page is available online, I can check it.
    #13966
    Zeus
    What is the suggestion of the scheme size.
    #13974
    Make sure that the size of the scheme document is large enough to contain all components. Otherwise, there can be side effects.
    https://ibb.co/mTZdnLz
