I’ve installed v5.8.4 and set up two elements (They belong to one RTU device, but have different data addresses) of a Modbus RTU device. If an error occurs when requesting the 1st element, the scada server cannot skip to request the next one after 3 retries. The server just requests the first element 3 times over and over again.
I don’t know how it was done in the 6th version, but in the 5th it is, after unsuccessful attempts, all other groups were not requested. This is the default action.
Thanks for your replys. Actually these two elements represent two devices connected to a Modbus RTU device which transmits the private protocol of above two devices to Modbus. Sometimes the 1st element/device needs to be shut down for maintenance or repair which will cause the error of the 1st request.
If I use a PLC (e.g. Siemens S7-200 Smart) as a Modbus master to access the above Modbus RTU device (a protocol converter). The master can jump to the next element if the 1st request fails. I had thought that Rapidscada would handle it in the same way.
In this case, split the single Modbus device into several devices having different templates.
There is no option to continue a session if a request fails. May be we should implement it in the future.
