lack of WinControl
Forum Home Forums Development and Integration lack of WinControl
  • #13841
    ipqiusheng
    when I re-complie ScadaCommShell, it remind me lack of WinControl, but when I use Nuget to get this package which you create on 2021, it only shows it need .net 6.0 dependency, but our ScadaCommShell targe framework is netframework 4.7.1, does that have some conflicts?or we need to update from netframework to .net6.0?
    • This topic was modified 2 years, 8 months ago by Mikhail.
    #13844
    Please provide a correct link to a screenshot. I deleted the incorrect link.
    #13851
    ScadaCommShell takes WinControl from this repository that should be downloaded either.
    #13852
    Rapid SCADA version 5 will be deprecated soon. Use Rapid SCADA 6.
    #13904
    ipqiusheng
    sorry,Mikhail, I still focus on your version 5 software, it give me more understand on whole structure, about WinControl this dll, When I downloaded from that repository, I didn’t find that, I try to use nuget, but it remind me it didn’t fit this project, but interesting I find that in installation package
    #13906
    ipqiusheng
    Hi
    Mikhail, do you have some thing like source code about wincontrol , I notice this also exist in scadaAdmin project, what this class use for?
    #13908
    ipqiusheng
    didn't set a initial value for wincontrol of ScadaAdmin
    hi
    mikhail, when I compile ScadaAdmin, I also meet the warning is:wincontrol is null, didn’t set a initial value for wincontrol variant, the warining locate in FrmMain.Designer.cs file, does it have some relationship with visual studio version? I use vs2022, previous i use winform and asp.net to compile program
    #13909
    ipqiusheng
    https://ibb.co/LkLXjqq this is image
    #13917
    WinControl source code is here.
    If you try to build v5, you need to download the dlls repository.
    #13925
    ipqiusheng
    Hi
    I re-build wincontrol in my computer, that can fix most of issues about wincontrol. it seems the dll from Nu-get repository has some issues which will cause install locally failed, not sure other guys if meet same issues.
    https://ibb.co/6RL98q9
    #13936
    WinControl 2.2.0 is created for the future use. This version is not compatible with current and previous versions of ScadaAdmin.
