503 Error
Forum Home › Forums › Runtime Bugs › Webstation Bugs › 503 Error
Viewing 6 posts - 1 through 6 (of 6 total)
  • #10215
    Jure
    Hi,
    we had setup a RapidScada at out customer and it was working fine for some time. Now when he tries to open scada on same computer (127.0.0.1/scada) he gets HTTP error 503.
    I checked server log and everything is ok. In administrator I can see that all 3 services are running and data is received.
    I checked port 10000 and I see that is being used by ScadaServerService, so it isn’t being used by some other application. What else could I try to find the source of this problem?
    • This topic was modified 4 years, 7 months ago by Mikhail.
    #10218
    Hi,
    This error is related to the web application that is run under IIS and usually uses port 80.
    Does the simple link http://localhost/ work?
    #10222
    Jure
    No it also doesn’t work.
    #10225
    It means that IIS can’t start.
    Check the TCP port 80 if it is in use by another app.
    #13945
    Dean92
    Hi Mikhail,
    I have the same issue, in my case IIS is running properly on PORT 80
    #13948
    Hi,
    What version of Rapid SCADA do you use?
    Did you check ScadaWeb.log?
