config file hot reload
Forum Home › Forums › New Ideas › config file hot reload
  • #10105
    Zeus
    It will be good if we can load cnl config without restart the scada server
    #10106
    If channel configuration changes, it requires compiling scripts, initializing of archives and modules.
    I agree that it would be good, but I don’t see easy way to implement it and make reliable.
    In v6 it’s possible to restart communication lines if Communicator configuration changes.
    #10107
    We plan to develop a module that allows to change the following configuration in runtime without restarting:
    1. Users
    2. Channel limits
    #13929
    Zeus
    Has the funtion been done?
    #13935
    In v6 channel limits can be bound to other channels, so they can be changed by an operator.
    User editing in runtime has not been implemented yet. Still in plan. The most similar option is using Active Directory to manage users. The is a module to auth user by Active Directory.
    #13941
    Zeus
