lack of Basic Control after compiling ScadaScheme
Forum Home › Forums › Development and Integration › lack of Basic Control after compiling ScadaScheme
  • #13905
    ipqiusheng
    https://ibb.co/QrDBQSc – scheme issues-lack of button and toggle switch after complied
    hi
    Guys
    do you meet some issues about compiling ScadaScheme.sln, when I try to degbug that, the list view control lack of basic control like toggle switch and Button
    • This topic was modified 2 years, 9 months ago by Mikhail.
    #13916
    You should put *.dll files to proper locations. I recommend to install Scheme Editor from the distributive, and check the required files in the installation folder.
    #13926
    ipqiusheng
    Hi
    do you mean we install distributive on computer, then we can run the source code and debug our project?
    #13937
    To run and debug the project you should manually copy the compiled files to the same locations which is used when you install Rapid SCADA from the distributive. This is because the compilation results of several projects is needed to run Rapid SCADA applications.
