Viewing 15 posts - 496 through 510 (of 6,387 total)
  • in reply to: Update new mimic plugins #16947
    August 31, 2025 update
    Fixed a bug when adding a component
    in reply to: Format – greater than 1000 characters #16942
    The string length is limited by the Administrator application. Actual length can be bigger.
    in reply to: Format – greater than 1000 characters #16941
    You could manually edit Format.xml in a text editor, e.g. Notepad++.
    Then reload the project or configuration database.
    in reply to: Localhost:10008 Not Working #16936
    OK.
    The similar topic is here.
    Thank you for the info.
    in reply to: How to report monthly totals per channel #16929
    If you use *.dat archives, they record data with a fixed period. So the number of records is constant.
    If PostgreSQL archives are used, you can count the number of records by SQL request.
    in reply to: New release Rapid SCADA 6.4.x #16926
    Rapid SCADA 6.4.2 has been released.
    Server:
    – Archives support monthly writing period
    – Added an option to continuously recalculate to the difference calculator module
    Communicator:
    – OPC UA driver has improved reconnection to the OPC server. Implemented channel-based subscription creation
    Webstation:
    – Beta version of new mimic diagrams included
    – Comamnd API is available by default
    – Changes in the plugin API
    Administrator:
    – The length of the Code field increased
    – Added more cultures in the culture list
    in reply to: How to report monthly totals per channel #16919
    > how many values were read for each channel
    Please clarify what does it mean “how many values were read”?
    in reply to: Closed serial port #16918
    If another software opens the port, it cannot be opened by Rapid SCADA.
    in reply to: Closed serial port #16917
    The software should try to open the port when it is available. What is in the log?
    In Rapid SCADA it’s a bit different:
    When you click a button, a popup dialog is shown, where you can choose an option.
    To do that, you need to configure a channel of the output type. Then specify the channel number in the button properties.
    in reply to: Logging fast I/O #16899
    Please don’t mess up many topics in one. Create new topic for other questions.
    Archive kind should be set to historical.
    in reply to: Logging fast I/O #16880
    Manually add a row in the Archives table.
    If you provide screenshots, I can check.
    in reply to: Execute weblink in channel table #16876
    That’s interesting!
    in reply to: Logging fast I/O #16873
    You can write data on change. It is supported by PostgreSQL archives.
    > Just for a selected channel, not all of them.
    It’s needed to create a new archive in the configuration database and in the Server settings. The created archive should not be marked as default. Then you can set an archive mask of the channel to write that channel to the certain archive.
    Ask for the details if needed.
